주요 콘텐츠로 건너뛰기
How to Restore a Bent Chopstick
필요한 것
  1. How to Restore a Bent Chopstick, How to Restore a Bent Chopstick: 1 단계, 이미지 1개 중 1개
    • Using a deep pan, fill the bottom with water.
    • Set the heat to medium/low until the water begins to simmer, then bring the flame to low.
    • Do not bring the water to a boil.
  2. How to Restore a Bent Chopstick: 2 단계, 이미지 1개 중 1개
    • Add salt into the pan, incorporating enough salt until the water is saturated. Mix until the salt dissolves.
    • The chopstick is made of a more firm plastic, so salt is necessary because the properties interact with one another to soften the plastic.
  3. How to Restore a Bent Chopstick: 3 단계, 이미지 2개 중 1개 How to Restore a Bent Chopstick: 3 단계, 이미지 2개 중 2개
    • Put on gloves to protect your hands from the heat, then gently add two dishes into the pan.
    • Ensure that the bowls will be able to tolerate the heat. The dishes are to help level the chopstick if your pan is not large enough to have the chopstick lie flat on the surface.
  4. How to Restore a Bent Chopstick: 4 단계, 이미지 1개 중 1개
    • Insert chopstick on top of the bowls. Make sure that the curve is facing upward.
    • When readjusting the chopstick, be sure to use tongs or other tools so you don't burn your fingers.
  5. How to Restore a Bent Chopstick: 5 단계, 이미지 1개 중 1개
    • Carefully take out the chopstick and gently temper by hand.
    • Be mindful of the heat when adjusting.
    • Be mindful of the strength you put into the chopstick. It may break if applying too much force.
  6. How to Restore a Bent Chopstick: 6 단계, 이미지 1개 중 1개
    • Repeat Step 4 and 5 until you attain the desired results.
결론
To reshape the chopstick, follow these instructions until it has straightened to satisfaction.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Lynne Nguyen
회원 가입일: 07/28/20
160 평판
안내서 1개를 작성함
UW Tacoma, Team S1-G10, Cardinal Summer 2020 UW Tacoma, Team S1-G10, Cardinal Summer 2020 회원
UWT-CARDINAL-SU20S1G10
1 회원
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 31
전체 시간: 2,733
