주요 콘텐츠로 건너뛰기
How to Restore a Damaged Cork Board
필요한 것
  1. How to Restore a Damaged Cork Board, How to Restore a Damaged Cork Board: 1 단계, 이미지 1/1
    • Cover your work surface with a tarp.
  2. How to Restore a Damaged Cork Board: 2 단계, 이미지 1/1
    • Use a rag, soap, and water to scrub the damaged area to remove residual pieces of cork and glue.
    • Allow the area to dry.
  3. How to Restore a Damaged Cork Board: 3 단계, 이미지 1/1
    • Apply wood filler liberally on top of the holes.
  4. How to Restore a Damaged Cork Board: 4 단계, 이미지 1/2 How to Restore a Damaged Cork Board: 4 단계, 이미지 2/2
    • Smooth out the wood filler using a putty knife.
    • Hold the putty knife at an angle and use long strokes to flatten the filler as much as possible.
    • Wait 1 hour for the filler to dry.
  5. How to Restore a Damaged Cork Board: 5 단계, 이미지 1/1
    • Use 80-grit sandpaper to sand down the excess filler in a circular motion.
  6. How to Restore a Damaged Cork Board: 6 단계, 이미지 1/1
    • Cover the damaged area with a thin, even layer of wood sealant.
결론
This guide will help you keep your old cork boards instead of trying to replace them. I hope you found our guide useful.
Annie Wilson
회원 가입일: 09/27/23
133 평판
안내서 1개 작성함
University of Arizona, Team 6-16, Cools Stephens Fall 2023 University of Arizona, Team 6-16, Cools Stephens Fall 2023 회원
ARIZONA-COOLS STEPHENS-F23S6G16
2 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 27
30일 전: 88
전체 시간: 519
