주요 콘텐츠로 건너뛰기
How to Restore a Dining Chair
필요한 것
  1. How to Restore a Dining Chair, How to Restore a Dining Chair: 1 단계, 이미지 3개 중 1개 How to Restore a Dining Chair, How to Restore a Dining Chair: 1 단계, 이미지 3개 중 2개 How to Restore a Dining Chair, How to Restore a Dining Chair: 1 단계, 이미지 3개 중 3개
    • Begin with an old chair frame.
    • For frames in good condition, continue to step 5.
    • Using your sandpaper, rub any marks or scuffs off the wood.
    • Always rub with the grain of the wood.
  2. How to Restore a Dining Chair: 2 단계, 이미지 2개 중 1개 How to Restore a Dining Chair: 2 단계, 이미지 2개 중 2개
    • Use the cleaning cloth to wipe off any excess dirt and dust.
  3. How to Restore a Dining Chair: 3 단계, 이미지 3개 중 1개 How to Restore a Dining Chair: 3 단계, 이미지 3개 중 2개 How to Restore a Dining Chair: 3 단계, 이미지 3개 중 3개
    • Holding the spray paint 6-12 inches away from the chair, apply a light coat of paint.
    • Allow it to dry for about 5 minutes.
    • Apply a second light coat over the front of the chair and allow it to dry for 10 minutes.
  4. How to Restore a Dining Chair: 4 단계, 이미지 2개 중 1개 How to Restore a Dining Chair: 4 단계, 이미지 2개 중 2개
    • Flip the chair over.
    • Repeat step 3 for the back side.
  5. How to Restore a Dining Chair: 5 단계, 이미지 3개 중 1개 How to Restore a Dining Chair: 5 단계, 이미지 3개 중 2개 How to Restore a Dining Chair: 5 단계, 이미지 3개 중 3개
    • While the paint dries, work on the seat.
    • Grab the wood board and set it down.
    • Grab the desired cushion and rest it on top of the board.
    • Make sure to align all four corners of the wood to the corners of the cushion.
  6. How to Restore a Dining Chair: 6 단계, 이미지 3개 중 1개 How to Restore a Dining Chair: 6 단계, 이미지 3개 중 2개 How to Restore a Dining Chair: 6 단계, 이미지 3개 중 3개
    • Now grab the cushion cover.
    • You may use fabric (cut to size) instead of a cushion cover.
    • Place your cover on top of the cushion, aligning all four corners.
  7. How to Restore a Dining Chair: 7 단계, 이미지 3개 중 1개 How to Restore a Dining Chair: 7 단계, 이미지 3개 중 2개 How to Restore a Dining Chair: 7 단계, 이미지 3개 중 3개
    • Grab the stack of wood, cushion and cover and flip it over.
    • Align them so they stack up evenly.
    • Fragments of the cushion cover may stick out a little.
  8. How to Restore a Dining Chair: 8 단계, 이미지 3개 중 1개 How to Restore a Dining Chair: 8 단계, 이미지 3개 중 2개 How to Restore a Dining Chair: 8 단계, 이미지 3개 중 3개
    • Fold the sides of the cover over the board and cushion keeping them as close to the center of the board as possible.
    • Select a side to start on.
    • With the staple gun, staple the end of the cushion cover you are holding into the board.
    • Rotate the board and staple down the other side.
    • Continue to staple down the sides, placing staples about 1 inch apart.
    • Fold the corners in and staple them onto the board.
  9. How to Restore a Dining Chair: 9 단계, 이미지 3개 중 1개 How to Restore a Dining Chair: 9 단계, 이미지 3개 중 2개 How to Restore a Dining Chair: 9 단계, 이미지 3개 중 3개
    • Make sure that the paint on the chair frame has completely dried up.
    • Grab your newly covered cushion and place it on the seat of the chair frame.
    • Holding on to both the cushion and the frame, flip the chair over.
  10. How to Restore a Dining Chair: 10 단계, 이미지 3개 중 1개 How to Restore a Dining Chair: 10 단계, 이미지 3개 중 2개 How to Restore a Dining Chair: 10 단계, 이미지 3개 중 3개
    • Place the screws in the screw holes.
    • Tighten the screws with the philips screw driver.
    • To avoid the wood from cracking, do not apply to much force when turning screwdriver.
  11. How to Restore a Dining Chair: 11 단계, 이미지 1개 중 1개
    • Make good use of your brand new chair.
결승점
다른 3명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Chuy Mercado
회원 가입일: 09/29/15
228 평판
안내서 1개를 작성함
Cal Poly, Team 15-6, Green Fall 2015 Cal Poly, Team 15-6, Green Fall 2015 회원
CPSU-GREEN-F15S15G6
5 회원들
안내서 6개를 작성함
2가이드 댓글
Do you have any Ideas on fixing a wobble chair before replacing the seat ?
Robert - 답글
Hi, I have a aoks chair I want to restore can you please help
Josefina Mejia - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 32
전체 시간: 6,962
