주요 콘텐츠로 건너뛰기
How to Restore a Torn Nike Flip-Flop
필요한 것
  1. How to Restore a Torn Nike Flip-Flop, How to Restore a Torn Nike Flip-Flop: 1 단계, 이미지 1개 중 1개
    • Remove all rough edges with 120 grit sandpaper from the torn parts of the flip-flop.
  2. How to Restore a Torn Nike Flip-Flop: 2 단계, 이미지 2개 중 1개 How to Restore a Torn Nike Flip-Flop: 2 단계, 이미지 2개 중 2개
    • Clean off any additional residue with soap, water, and a towel or toothbrush.
    • Allow the flip-flop to air dry before moving on.
  3. How to Restore a Torn Nike Flip-Flop: 3 단계, 이미지 1개 중 1개
    • Gently apply the adhesive on the torn parts of the flip-flop.
    • Make sure the torn parts are completely covered. Overspill is okay.
    • Connect and hold the parts of the flip-flop to the adhesive with your hands for 5 minutes. After the 5 minutes the adhesive will be hard enough to let it sit. Let the adhesive dry for 24 hours.
    • Be sure to wear gloves and be in a ventilated environment when applying the adhesive.
  4. How to Restore a Torn Nike Flip-Flop: 4 단계, 이미지 1개 중 1개
    • Once the adhesive is dry remove any extra adhesive that might have spilled over with the sandpaper.
  5. How to Restore a Torn Nike Flip-Flop: 5 단계, 이미지 3개 중 1개 How to Restore a Torn Nike Flip-Flop: 5 단계, 이미지 3개 중 2개 How to Restore a Torn Nike Flip-Flop: 5 단계, 이미지 3개 중 3개
    • Take the needle and thread and begin to sew a cross stitch from the strap to the torn part of the flip-flop.
    • It may be easier to use an upholstery needle to get through the rubber material.
  6. How to Restore a Torn Nike Flip-Flop: 6 단계, 이미지 1개 중 1개
    • Cover the stitched region with Plasti Dip.
    • Allow 4 hours to dry.
    • Make sure to apply the Plastic Dip in a proper environment with venalation or outside.
결론
The Nike Flip-Flop(s) are now restored and can be worn again.
다른 7명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Adrian Yearby
회원 가입일: 07/12/17
265 평판
안내서 1개를 작성함
Texas Tech, Team S1-G2, Rauch Summer 2017 Texas Tech, Team S1-G2, Rauch Summer 2017 회원
TTU-RAUCH-SU17S1G2
2 회원들
안내서 2개를 작성함
2가이드 댓글
Hi Andrew! Thank you so much for this example. What kind of adhesive did you use, because there are so many versions. Thank you.
masood daud - 답글
Oh darn I see it now.lol
masood daud - 답글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 23
지난 30일: 79
전체 시간: 19,321
