주요 콘텐츠로 건너뛰기
How to Restore a Used Canvas
필요한 것
  1. How to Restore a Used Canvas, How to Restore a Used Canvas: 1 단계, 이미지 1/2 How to Restore a Used Canvas, How to Restore a Used Canvas: 1 단계, 이미지 2/2
    • Insert a spudger beneath a staple and pry upwards to remove it.
    • Repeat for the remaining staples.
    • Caution: Be careful when handling sharp staples.
  2. How to Restore a Used Canvas: 2 단계, 이미지 1/2 How to Restore a Used Canvas: 2 단계, 이미지 2/2
    • Remove the canvas and place the wood frame aside
    • Lay out the used canvas flat on a clean surface.
    • Wipe the canvas down with a damp cloth.
  3. How to Restore a Used Canvas: 3 단계, 이미지 1/1
    • Gently use fine grit sandpaper to remove any old clumps of paint on the canvas.
  4. How to Restore a Used Canvas: 4 단계, 이미지 1/3 How to Restore a Used Canvas: 4 단계, 이미지 2/3 How to Restore a Used Canvas: 4 단계, 이미지 3/3
    • Add an even layer of white acrylic paint on the entire canvas.
    • Use a paintbrush to evenly spread the paint on the canvas.
  5. How to Restore a Used Canvas: 5 단계, 이미지 1/1
    • To make the drying process faster, use a portable fan or hairdryer.
    • Continue to paint even layers until the canvas is covered evenly.
  6. How to Restore a Used Canvas: 6 단계, 이미지 1/1
    • After the paint is completely dry, lightly sand down any noticeable bumps to get a smooth finish on the canvas.
  7. How to Restore a Used Canvas: 7 단계, 이미지 1/3 How to Restore a Used Canvas: 7 단계, 이미지 2/3 How to Restore a Used Canvas: 7 단계, 이미지 3/3
    • Grab the wood frame and fold one side of the canvas to its original state.
    • Tightly secure the canvas and firmly set the stapler on the area that needs a staple.
    • With a steady and secure fist, firmly press on the top of the stapler.
    • Continue this process all around the canvas.
  8. How to Restore a Used Canvas: 8 단계, 이미지 1/3 How to Restore a Used Canvas: 8 단계, 이미지 2/3 How to Restore a Used Canvas: 8 단계, 이미지 3/3
    • Tightly fold the corners of the canvas and secure it with a final staple keeping it in place.
결승점
Sandra Henriquez
회원 가입일: 04/21/21
157 평판
안내서 1개 작성함
CSU Los Angeles, Team S1-G7, Harris Spring 2021 CSU Los Angeles, Team S1-G7, Harris Spring 2021 회원
CSULA-HARRIS-S21S1G7
2 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 30
전체 시간: 623
