주요 콘텐츠로 건너뛰기
How to Restring Cellular Shades
필요한 것
  1. How to Restring Cellular Shades, Restringing Cellular Shades: 1 단계, 이미지 3개 중 1개 How to Restring Cellular Shades, Restringing Cellular Shades: 1 단계, 이미지 3개 중 2개 How to Restring Cellular Shades, Restringing Cellular Shades: 1 단계, 이미지 3개 중 3개
    • Unscrew the tassel and set aside.
    • Using a flathead screwdriver, open the cord stop, remove from the strings, and set aside.
  2. How to Restring Cellular Shades: 2 단계, 이미지 1개 중 1개
    • Close the shade and push up, sliding the shade out toward the center of the room.
    • This is a common method for taking down a cellular shade but not all shades are hung the same way. Use the appropriate method for your shade.
    • Place the shade on a flat surface to work on.
  3. How to Restring Cellular Shades: 3 단계, 이미지 2개 중 1개 How to Restring Cellular Shades: 3 단계, 이미지 2개 중 2개
    • Measure and cut the new nylon strings. To be safe, the length should be equal to the sum of the window width and twice the window height. There will be excess string and it will be cut off in step 14.
    • Length = (Window Width) + 2*(Window Height)
  4. How to Restring Cellular Shades: 4 단계, 이미지 3개 중 1개 How to Restring Cellular Shades: 4 단계, 이미지 3개 중 2개 How to Restring Cellular Shades: 4 단계, 이미지 3개 중 3개
    • Use the flathead screwdriver to take the end caps off of the top rail and set aside.
    • Take out the screw using the phillips screwdriver and slide the top rail off.
    • Using the needle nose pliers, push the cord lock clips in from the side and slide the cord lock out, removing the strings and setting the cord lock aside.
  5. How to Restring Cellular Shades: 5 단계, 이미지 2개 중 1개 How to Restring Cellular Shades: 5 단계, 이미지 2개 중 2개
    • Flip the shade over and pull the end caps off of the bottom rail. Set them aside.
    • Slide the bottom rail off and set aside.
  6. How to Restring Cellular Shades: 6 단계, 이미지 2개 중 1개 How to Restring Cellular Shades: 6 단계, 이미지 2개 중 2개
    • Untie the ends of the strings between the weights on the bottom of the shade.
    • Pull the strings out of the shade and discard.
  7. How to Restring Cellular Shades: 7 단계, 이미지 3개 중 1개 How to Restring Cellular Shades: 7 단계, 이미지 3개 중 2개 How to Restring Cellular Shades: 7 단계, 이미지 3개 중 3개
    • Thread the new string through the restringing needle.
    • Pull the needle and thread through the shade, making sure to leave three inches out of the bottom side of the shade.
    • Repeat for the other strings.
  8. How to Restring Cellular Shades: 8 단계, 이미지 2개 중 1개 How to Restring Cellular Shades: 8 단계, 이미지 2개 중 2개
    • Tie a knot with the 3 inch piece and pull the string tight.
  9. How to Restring Cellular Shades: 9 단계, 이미지 3개 중 1개 How to Restring Cellular Shades: 9 단계, 이미지 3개 중 2개 How to Restring Cellular Shades: 9 단계, 이미지 3개 중 3개
    • Slide the bottom rail back onto the shade.
    • Push the bottom end caps back onto the rail.
  10. How to Restring Cellular Shades: 10 단계, 이미지 1개 중 1개
    • Turn the top rail over so that the top is on the work surface.
    • Thread the strings through the small gap in the top rail that the cord lock was removed from.
    • The ends of the strings should be on the outer side of the top rail.
  11. How to Restring Cellular Shades: 11 단계, 이미지 3개 중 1개 How to Restring Cellular Shades: 11 단계, 이미지 3개 중 2개 How to Restring Cellular Shades: 11 단계, 이미지 3개 중 3개
    • Restring the cord lock by first picking up the strings coming out of the cord lock gap. Thread them through the side opening of the cord lock and out of the back opening.
    • Thread them back through the back opening and out of the front opening. Make sure to pass the strings through the black rectangular piece inside the cord lock.
    • Pull the strings tight so that the strings are only in the front and side openings.
  12. How to Restring Cellular Shades: 12 단계, 이미지 3개 중 1개 How to Restring Cellular Shades: 12 단계, 이미지 3개 중 2개 How to Restring Cellular Shades: 12 단계, 이미지 3개 중 3개
    • Insert the cord lock into the gap in the top rail with the opaque plastic side facing up.
    • Lay the strings down the middle of the shade.
    • Slide the top rail onto the shade, pulling the strings tight through the cord lock.
    • The end of the rail without the cord lock should be slid on first.
  13. How to Restring Cellular Shades: 13 단계, 이미지 2개 중 1개 How to Restring Cellular Shades: 13 단계, 이미지 2개 중 2개
    • Use the phillips screwdriver to put the screw back into the top rail.
    • Push the end caps back into place.
  14. How to Restring Cellular Shades: 14 단계, 이미지 2개 중 1개 How to Restring Cellular Shades: 14 단계, 이미지 2개 중 2개
    • Rehang the shade by pushing the shade up into the clips and sliding it towards the window.
    • This is a common method for rehanging cellular shades but not all shades are hung the same way. Use the appropriate method for your shade.
    • Open the shade and cut the strings so the ends are halfway up the shade.
  15. How to Restring Cellular Shades: 15 단계, 이미지 2개 중 1개 How to Restring Cellular Shades: 15 단계, 이미지 2개 중 2개
    • Place the strings inside the cord stop and close it.
    • Adjust the cord stop to your liking.
  16. How to Restring Cellular Shades: 16 단계, 이미지 3개 중 1개 How to Restring Cellular Shades: 16 단계, 이미지 3개 중 2개 How to Restring Cellular Shades: 16 단계, 이미지 3개 중 3개
    • Slide the top half of the tassel over the ends of the strings and tie the ends together.
    • Screw the lower half of the tassel onto the top half.
결론
Once you have completed the steps for restringing your cellular shade, it is ready for use. Test it out!
다른 4명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Tirzah Eyre
회원 가입일: 01/12/18
370 평판
안내서 1개를 작성함
6가이드 댓글
Are the directions different for top down/bottom up shades?
toewsfam11 - 답글
Hi - thank you so much for this post. I followed it picture by picture and managed to restring my blind which was broken. I had been quoted NZ$150 to have it fixed so though - I may as well try to DIY and see how I went. I was nervous and had to go back and forth a few times with the steps but all in all it took me about an hour to do this job and I am so happy. String cost me NZ$12.99 and there’s plenty more to do another blind! Thank you again.
Beth Houston - 답글
Tirzah, this is EXACTLY what I needed. My shades were slightly different (ie. the lock mechanism), but this gave me the general idea (and specifics in most areas) that helped me know how to tackle this! :) It wasn’t easy (took me 1.5 hours), but… it’s DONE! Thanks again!! :D Kurt
Kurt S - 답글
I’m trying to repair a cordless shade. It uses a spring ( a coil) but I haven’t been able to find a seller of this parts. Any help is welcome.
Fab - 답글
Where did you buy the replacement string?
Happy Flower - 답글
댓글 쓰기
조회 통계:
지난 24시간: 9
지난 7일: 56
지난 30일: 239
전체 시간: 40,004
