소개
Badminton racquets become unusable when their strings are broken, damaged, or without tension. Damage to a racquet may result from normal wear and tear. Restringing a badminton racquet by hand is non-hazardous and doesn't require any special machines or tools. To restore a racquet to playing condition, you just need a racquet frame, undamaged strings, and patience!
Recreational badminton players can get back on the court without spending money on a new racquet or professional restringing services.
필요한 것
Insert one end of the string through the hole at the bottom of the racquet closest to the shaft and drag it straight up to the corresponding hole at the top of the raquet.
Use your fingers to make a knot (you may need to make two knots on top of each other so the string can't slide back through the hole).
Pull on each strand, beginning with the outermost strand with the knot, and move towards the middle so that the string tightens up and becomes taut.
At the end of the strand (right when the racquet naturally begins to curve), pull the strings tight. You may need to pull on each strand from the base up to get rid of any slack in the string. Make sure the tension in the strings is very high and there is little give when you push down on the strings with your hand.
Your final product is ready. The strings should not move much when you gently push down on them with your hand.
It's ok if put arrow marks in the diagram so it's much easier to understand.anyeayvtqcforvthe tips.
다른 10명이 해당 안내서를 완성하였습니다.
댓글 3개
Very Simple and easily understandable guideline.
I request Sabina to please include guidelines on automatic stringing Badminton machine(Siboasi)with steps and images.
If possible please send me on my email address(dvc870621@gmail.com).
Thanks
Deepak Chaudhari
Would only recommend this method for very cheap rackets, but at that price point, it is very possible that the cost of the string will exceed the price of a new racket.
Never tie off the on the outside of the racket as this leads to increased stress on the frame.
Did this for the first time on an older racket and I am impressed, had to experiment a bit with different tie of knots but got there in the end. The final tension isn't super tight but I have ideas to improve this in the future attempts, but still quite happy for the first attempt. Just a note that, it will require ¬10m length of string to fully string a racket. Thanks.
