주요 콘텐츠로 건너뛰기
How to Restring a French Horn
필요한 것
  1. How to Restring a French Horn, How to Restring a French Horn: 1 단계, 이미지 3개 중 1개 How to Restring a French Horn, How to Restring a French Horn: 1 단계, 이미지 3개 중 2개 How to Restring a French Horn, How to Restring a French Horn: 1 단계, 이미지 3개 중 3개
    • Place your horn where the back is easily accessible.
    • Loosen the set of screws, but DON’T take them out! Just loosen them enough that the string can wrap around.
  2. How to Restring a French Horn: 2 단계, 이미지 3개 중 1개 How to Restring a French Horn: 2 단계, 이미지 3개 중 2개 How to Restring a French Horn: 2 단계, 이미지 3개 중 3개
    • Cut about 7-8 inches of string only if you are going to use a brand new roll of string, and tie a small knot on one end of the string.
    • If it is the exact string, make sure there is a knot at the one end of the string.
    • With the knot, the string should be about 51/2-6 inches.
  3. How to Restring a French Horn: 3 단계, 이미지 2개 중 1개 How to Restring a French Horn: 3 단계, 이미지 2개 중 2개
    • Put the string in the top hole of the valve and pull.
    • You are going to pull it toward the bottom and wrap it at the bottom of the rotor post.
  4. How to Restring a French Horn: 4 단계, 이미지 3개 중 1개 How to Restring a French Horn: 4 단계, 이미지 3개 중 2개 How to Restring a French Horn: 4 단계, 이미지 3개 중 3개
    • Wrap the string around the screw and tighten the screw.
  5. How to Restring a French Horn: 5 단계, 이미지 3개 중 1개 How to Restring a French Horn: 5 단계, 이미지 3개 중 2개 How to Restring a French Horn: 5 단계, 이미지 3개 중 3개
    • Pull the string to wrap the top of the rotor.
    • Put the string into the hole at the bottom of the valve.
  6. How to Restring a French Horn: 6 단계, 이미지 3개 중 1개 How to Restring a French Horn: 6 단계, 이미지 3개 중 2개 How to Restring a French Horn: 6 단계, 이미지 3개 중 3개
    • Wrap the string around the screw.
    • Tighten the screw.
  7. How to Restring a French Horn: 7 단계, 이미지 3개 중 1개 How to Restring a French Horn: 7 단계, 이미지 3개 중 2개 How to Restring a French Horn: 7 단계, 이미지 3개 중 3개
    • Make sure your valve buttons are leveled, if it is too tight or to loose where it is not leveled, then you will have to repeat steps 1-6.
    • If your horn looks like any of these photos then congrats!! You are finished.
    • You may now move on with your day and go practice! Make sure to press the valve a coupe of times to make sure everything is secure well.
결론
작성자
1다른 기여자 명과 함께
Claudia aguilar
회원 가입일: 04/16/24
145 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 16
지난 30일: 50
전체 시간: 454
