주요 콘텐츠로 건너뛰기
How to Restuff a Plushie
필요한 것
  1. How to Restuff a Plushie, How to Restuff a Plushie: 1 단계, 이미지 1개 중 1개
    • Choose an area to open the seam of the plushie.
    • Choose an area where the new stitches will not be as noticeable, such as on an underside or another area that will not be seen.
  2. How to Restuff a Plushie: 2 단계, 이미지 3개 중 1개 How to Restuff a Plushie: 2 단계, 이미지 3개 중 2개 How to Restuff a Plushie: 2 단계, 이미지 3개 중 3개
    • Partially unpick the seam using a seam ripper or pair of scissors (about 2 inches).
    • Be sure to place hands carefully and away from the path of the seam ripper to ensure no injures.
  3. How to Restuff a Plushie: 3 단계, 이미지 2개 중 1개 How to Restuff a Plushie: 3 단계, 이미지 2개 중 2개
    • Remove all of the old stuffing from the plushie.
  4. How to Restuff a Plushie: 4 단계, 이미지 3개 중 1개 How to Restuff a Plushie: 4 단계, 이미지 3개 중 2개 How to Restuff a Plushie: 4 단계, 이미지 3개 중 3개
    • Fill a sink or bowl with warm water and light detergent.
    • Gently hand wash your plushie.
    • Drain and replace the container with clean and warm water.
    • Rinse off the plushie and wring it until it is no longer dripping.
  5. How to Restuff a Plushie: 5 단계, 이미지 1개 중 1개
    • Hang dry the plushie using a hanger or clothesline until completely dry.
    • Machine drying can damage or burn the fabric of the plushie
  6. How to Restuff a Plushie: 6 단계, 이미지 3개 중 1개 How to Restuff a Plushie: 6 단계, 이미지 3개 중 2개 How to Restuff a Plushie: 6 단계, 이미지 3개 중 3개
    • Once dry, fill the plushie with new stuffing.
    • Stuffing the plushie little by little ensures the whole plushie gets re-stuffed properly and evenly.
  7. How to Restuff a Plushie: 7 단계, 이미지 3개 중 1개 How to Restuff a Plushie: 7 단계, 이미지 3개 중 2개 How to Restuff a Plushie: 7 단계, 이미지 3개 중 3개
    • Pull the thread through the eye of the needle.
    • Create a knot at the end of the thread.
  8. How to Restuff a Plushie: 8 단계, 이미지 1개 중 1개
    • Fold the fabric of the opening (about 1 cm) inward to create two folds.
  9. How to Restuff a Plushie: 9 단계, 이미지 3개 중 1개 How to Restuff a Plushie: 9 단계, 이미지 3개 중 2개 How to Restuff a Plushie: 9 단계, 이미지 3개 중 3개
    • Insert the needle through the inside edge of the folded fabric
    • Make a stitch in the inside fold and pull the thread through.
    • Insert the needle on the other fold and make a stitch
    • Pull the thread through and alternate stitches until you reach the other side of the opening.
    • Take your time and carefully place your hands in a safe position when inserting the needle into the fabric. This can prevent injures.
  10. How to Restuff a Plushie: 10 단계, 이미지 3개 중 1개 How to Restuff a Plushie: 10 단계, 이미지 3개 중 2개 How to Restuff a Plushie: 10 단계, 이미지 3개 중 3개
    • Thread the needle through the inside stitches to loop and knot the end of the thread.
    • Repeat several times to secure the stitch.
  11. How to Restuff a Plushie: 11 단계, 이미지 2개 중 1개 How to Restuff a Plushie: 11 단계, 이미지 2개 중 2개
    • Cut the excess thread with scissors.
  12. How to Restuff a Plushie: 12 단계, 이미지 1개 중 1개
    • Enjoy your renewed plushie!
결론
Your plushie is now looking almost brand new!
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Sally Lee
회원 가입일: 02/01/24
220 평판
안내서 1개를 작성함
UC Davis, Team 2-4, Andersen Winter 2024 UC Davis, Team 2-4, Andersen Winter 2024 회원
UCD-ANDERSEN-W24S2G4
3 회원들
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 29
지난 30일: 162
전체 시간: 1,230
