소개
Fishing lures can be scratched or damaged in many ways as a resuIt of bouncing off rocks, becoming snagged, or worn from use. Scratches prevent metal lures from shining and attracting fish. In addition, wooden lures may absorb water which decreases their buoyancy. To initiate this repair you will need gloves, sandpaper, a can of liquid indoor/outdoor polyurethane, and possibly a pair of pliers. This project should be performed in a well ventilated area because of the polyurethane and the sanding required.
필요한 것
Evaluate the material your lures are made from. This will affect your process slightly.
All that is necessary after the lure's new surface has cured is to reattach the keyring and treble hooks.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 2개
Looking for your first rod so you can take part in the great sport of fishing? Have you looked through some catalogs or browsed in sporting goods store and are already confused? All these new words to learn. Spinning fishing rods? Bait-casting '''fishing rods'''? Spin casting fishing rods? What do all these things mean?
Very interesting post. Every step explains with the images are really helpful for the beginners. I love fishing in Puerto Vallarta and your post helps me a lot to resurface my fishing lure. Thanks a million and please keep up the effective work.
