주요 콘텐츠로 건너뛰기
How to Rethread Skateboard Axle Trucks
필요한 것
  1. How to Rethread Skateboard Axle Trucks, How to Rethread Skateboard Axle Trucks: 1 단계, 이미지 2개 중 1개 How to Rethread Skateboard Axle Trucks, How to Rethread Skateboard Axle Trucks: 1 단계, 이미지 2개 중 2개
    • Begin by removing the wheel by removing the old nut with a skate tool.
    • Remember that you have a stripped axle, so you may need extra force to remove the nut.
  2. How to Rethread Skateboard Axle Trucks: 2 단계, 이미지 1개 중 1개
    • Clean off any excess dirt or metal particles with a dry towel.
    • Your towel should be dry. Cleaning the axle with a wet towel may cause the axle to rust.
  3. How to Rethread Skateboard Axle Trucks: 3 단계, 이미지 3개 중 1개 How to Rethread Skateboard Axle Trucks: 3 단계, 이미지 3개 중 2개 How to Rethread Skateboard Axle Trucks: 3 단계, 이미지 3개 중 3개
    • Insert the axle thread tool into the 1/2" socket on the skate tool.
    • With the thread tool in the socket, insert the axle into the tool and turn your skate tool clockwise throughout the entire axle. Once you feel you have reached the end of the axle, unscrew the tool.
  4. How to Rethread Skateboard Axle Trucks: 4 단계, 이미지 2개 중 1개 How to Rethread Skateboard Axle Trucks: 4 단계, 이미지 2개 중 2개
    • Inspect your threads for their quality. You should now have even threads with deep grooves. If they appear uneven, you may need to go back and repeat step 4.
    • Place your wheel back on the axle.
  5. How to Rethread Skateboard Axle Trucks: 5 단계, 이미지 3개 중 1개 How to Rethread Skateboard Axle Trucks: 5 단계, 이미지 3개 중 2개 How to Rethread Skateboard Axle Trucks: 5 단계, 이미지 3개 중 3개
    • Discard the old wheel nut and replace it with a new one. Tighten the new nut onto the wheel.
    • Ensure that your new wheel nut is seated correctly on the threads.
    • Be careful not to overtighten the new nut to prevent stripping the axle again.
결론
Congrats on learning how to repair a stripped axle. Hopefully this guide helped you get back on your wheels!
작성자
1다른 기여자 명과 함께
Angel A Cardenas
회원 가입일: 03/25/24
121 평판
안내서 1개를 작성함
CSU Los Angeles, Team 8-1, Briggs Spring 2024 CSU Los Angeles, Team 8-1, Briggs Spring 2024 회원
CSULA-BRIGGS-S24S8G1
3 회원들
안내서 3개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 7
전체 시간: 209
