주요 콘텐츠로 건너뛰기
How to Reupholster a Bench Cushion
필요한 것
  1. How to Reupholster a Bench Cushion, How to Reupholster a Bench Cushion: 1 단계, 이미지 3개 중 1개 How to Reupholster a Bench Cushion, How to Reupholster a Bench Cushion: 1 단계, 이미지 3개 중 2개 How to Reupholster a Bench Cushion, How to Reupholster a Bench Cushion: 1 단계, 이미지 3개 중 3개
    • Remove the base from the frame of the bench.
    • If the base is screwed on the frame, use a screwdriver or a drill to remove the screws.
  2. How to Reupholster a Bench Cushion: 2 단계, 이미지 3개 중 1개 How to Reupholster a Bench Cushion: 2 단계, 이미지 3개 중 2개 How to Reupholster a Bench Cushion: 2 단계, 이미지 3개 중 3개
    • Lift the staples with the flathead screwdriver before going in with the pliers.
  3. How to Reupholster a Bench Cushion: 3 단계, 이미지 3개 중 1개 How to Reupholster a Bench Cushion: 3 단계, 이미지 3개 중 2개 How to Reupholster a Bench Cushion: 3 단계, 이미지 3개 중 3개
    • Use a pair of pliers to grip the staples.
    • Twist and pull the staples to remove them from the bench.
  4. How to Reupholster a Bench Cushion: 4 단계, 이미지 3개 중 1개 How to Reupholster a Bench Cushion: 4 단계, 이미지 3개 중 2개 How to Reupholster a Bench Cushion: 4 단계, 이미지 3개 중 3개
    • Place clean material down so the new fabric does not get dirty.
    • Place the fabric with the design face down on top of the clean sheet.
    • Then place the cushion, then the base face down.
  5. How to Reupholster a Bench Cushion: 5 단계, 이미지 3개 중 1개 How to Reupholster a Bench Cushion: 5 단계, 이미지 3개 중 2개 How to Reupholster a Bench Cushion: 5 단계, 이미지 3개 중 3개
    • Keep the safety lock closed when not using the staple gun.
    • When ready to use the staple gun, pull the safety lock down.
    • Insert the staples into the stapler.
  6. How to Reupholster a Bench Cushion: 6 단계, 이미지 3개 중 1개 How to Reupholster a Bench Cushion: 6 단계, 이미지 3개 중 2개 How to Reupholster a Bench Cushion: 6 단계, 이미지 3개 중 3개
    • Pull the fabric taut and staple every 4 inches.
  7. How to Reupholster a Bench Cushion: 7 단계, 이미지 3개 중 1개 How to Reupholster a Bench Cushion: 7 단계, 이미지 3개 중 2개 How to Reupholster a Bench Cushion: 7 단계, 이미지 3개 중 3개
    • Fold the corners of the fabric inward then on top.
    • Staple the fabric down twice for each corner.
    • Cut the excess fabric along the shorter sides of the base length.
    • Place the base back onto the frame.
    • If any screws were removed, screw them back on.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Xochitl Vara
회원 가입일: 01/26/22
169 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 19
전체 시간: 727
