주요 콘텐츠로 건너뛰기
How to Reuse Dry Nail Polish
필요한 것
  1. How to Reuse Dry Nail Polish, How to Reuse Dry Nail Polish: 1 단계, 이미지 1개 중 1개
    • Find a clean workplace where you can easily clean up spills.
    • DO NOT USE ACETONE TO THIN THE NAIL POLISH. Acetone is a solvent for removing nail polish. It can make the nail polish work but, the end result is dull or lumpy nail polish.
    • You can use a few drops of 91% isopropyl alcohol or ethyl acetate as solvents for thinning nail polish.
  2. How to Reuse Dry Nail Polish: 2 단계, 이미지 2개 중 1개 How to Reuse Dry Nail Polish: 2 단계, 이미지 2개 중 2개
    • Open the bottle of dry nail polish setting the brush to the side.
    • Open the bottle of nail polish thinner.
    • Squirt 2 drops of nail polish thinner into the dry nail polish.
    • Screw the top back onto the dry nail polish and roll the bottle between your hands to mix. Shaking the bottle can put air bubbles in the nail polish and ruin a manicure.
    • Be careful to not not spill any nail polish thinner.
  3. How to Reuse Dry Nail Polish: 3 단계, 이미지 2개 중 1개 How to Reuse Dry Nail Polish: 3 단계, 이미지 2개 중 2개
    • If the nail polish is still dry or thick repeat steps 2-3 until the nail polish is finally thinned.
    • Do not apply too much nail polish thinner, this will result in watery nail polish.
결론
The nail polish should reach its regular consistency after applying the nail thinner. You may then be able to apply your nail polish onto your nails.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Iridian Vaca
회원 가입일: 04/09/15
289 평판
안내서 1개를 작성함
Cal Poly, Team 28-5, Green Spring 2015 Cal Poly, Team 28-5, Green Spring 2015 회원
CPSU-GREEN-S15S28G5
3 회원들
안내서 12개를 작성함
1가이드 댓글
If the nail polish is just thick, you can run hot water over the bottle for a few minutes to thin it down some. You don't want to shake a bottle of nail polish to mix it, it can put air bubbles in the mixture, instead roll the bottle between your hands. Nice first guide, GL here.
ABCellars - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 50
전체 시간: 26,743
