주요 콘텐츠로 건너뛰기
How to Rewire a Lamp
필요한 것
  1. How to Rewire a Lamp, Cord: 1 단계, 이미지 1/3 How to Rewire a Lamp, Cord: 1 단계, 이미지 2/3 How to Rewire a Lamp, Cord: 1 단계, 이미지 3/3
    • Before starting the process, remove the lamp shade and bulb by hand.
    • Make sure the lamp is unplugged to avoid the risk of electrocution.
  2. How to Rewire a Lamp: 2 단계, 이미지 1/3 How to Rewire a Lamp: 2 단계, 이미지 2/3 How to Rewire a Lamp: 2 단계, 이미지 3/3
    • Loosen the setscrew with the screwdriver so you can unscrew the socket base.
    • Unscrew the socket base from the threaded tube with your hand.
  3. How to Rewire a Lamp: 3 단계, 이미지 1/3 How to Rewire a Lamp: 3 단계, 이미지 2/3 How to Rewire a Lamp: 3 단계, 이미지 3/3
    • With your hand, pry the socket shell out of its base.
    • Remove the socket with your hand and then cut the wires with the wire cutters.
    • The neutral wire connects to the wide plug blade and is distinguished from the hot wire by ribs, color, printing, or indentations in the plastic insulation.
  4. How to Rewire a Lamp: 4 단계, 이미지 1/2 How to Rewire a Lamp: 4 단계, 이미지 2/2
    • Strip off 1/2" of the insulation with the wire stripper and twist the wire strands together by hand.
    • If you pull off any wire strands while stripping, cut back the cord with the Diagonal cutter.
  5. How to Rewire a Lamp: 5 단계, 이미지 1/3 How to Rewire a Lamp: 5 단계, 이미지 2/3 How to Rewire a Lamp: 5 단계, 이미지 3/3
    • By hand, tie an underwriters knot in the cord.
    • Also by hand, connect the wires by wrapping them clockwise around the screws and tighten and connect the neutral wire to the silver screw.
    • An underwriter's knot prevents the wires from pulling out of the screw terminals when cord is tugged. ( The entire process of tying an underwriter knot can be done by hand . Form a loop using the first wire. Then, form a loop around the first wire and pass the tail through its loop. The strain on the cable is now taken by the knot.)
  6. How to Rewire a Lamp: 6 단계, 이미지 1/3 How to Rewire a Lamp: 6 단계, 이미지 2/3 How to Rewire a Lamp: 6 단계, 이미지 3/3
    • By hand, pull the excess cord down through the lamp.
    • Still using your hand, slip the insulation sleeve and socket shell over the socket and snap the shell into the base.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
Molly
회원 가입일: 10/20/17
119 평판
안내서 1개 작성함
Missouri Western, Team S1-G4, Adkins Fall 2017 Missouri Western, Team S1-G4, Adkins Fall 2017 회원
MWSU-ADKINS-F17S1G4
3 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 18
전체 시간: 1,330
