주요 콘텐츠로 건너뛰기
How to Rewire a Lamp
필요한 것
  1. How to Rewire a Lamp, Cord: 1 단계, 이미지 3개 중 1개 How to Rewire a Lamp, Cord: 1 단계, 이미지 3개 중 2개 How to Rewire a Lamp, Cord: 1 단계, 이미지 3개 중 3개
    • Before starting the process, remove the lamp shade and bulb by hand.
    • Make sure the lamp is unplugged to avoid the risk of electrocution.
  2. How to Rewire a Lamp: 2 단계, 이미지 3개 중 1개 How to Rewire a Lamp: 2 단계, 이미지 3개 중 2개 How to Rewire a Lamp: 2 단계, 이미지 3개 중 3개
    • Loosen the setscrew with the screwdriver so you can unscrew the socket base.
    • Unscrew the socket base from the threaded tube with your hand.
  3. How to Rewire a Lamp: 3 단계, 이미지 3개 중 1개 How to Rewire a Lamp: 3 단계, 이미지 3개 중 2개 How to Rewire a Lamp: 3 단계, 이미지 3개 중 3개
    • With your hand, pry the socket shell out of its base.
    • Remove the socket with your hand and then cut the wires with the wire cutters.
    • The neutral wire connects to the wide plug blade and is distinguished from the hot wire by ribs, color, printing, or indentations in the plastic insulation.
  4. How to Rewire a Lamp: 4 단계, 이미지 2개 중 1개 How to Rewire a Lamp: 4 단계, 이미지 2개 중 2개
    • Strip off 1/2" of the insulation with the wire stripper and twist the wire strands together by hand.
    • If you pull off any wire strands while stripping, cut back the cord with the Diagonal cutter.
  5. How to Rewire a Lamp: 5 단계, 이미지 3개 중 1개 How to Rewire a Lamp: 5 단계, 이미지 3개 중 2개 How to Rewire a Lamp: 5 단계, 이미지 3개 중 3개
    • By hand, tie an underwriters knot in the cord.
    • Also by hand, connect the wires by wrapping them clockwise around the screws and tighten and connect the neutral wire to the silver screw.
    • An underwriter's knot prevents the wires from pulling out of the screw terminals when cord is tugged. ( The entire process of tying an underwriter knot can be done by hand . Form a loop using the first wire. Then, form a loop around the first wire and pass the tail through its loop. The strain on the cable is now taken by the knot.)
  6. How to Rewire a Lamp: 6 단계, 이미지 3개 중 1개 How to Rewire a Lamp: 6 단계, 이미지 3개 중 2개 How to Rewire a Lamp: 6 단계, 이미지 3개 중 3개
    • By hand, pull the excess cord down through the lamp.
    • Still using your hand, slip the insulation sleeve and socket shell over the socket and snap the shell into the base.
결승점
다른 3명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Molly
회원 가입일: 10/20/17
125 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 20
지난 30일: 98
전체 시간: 2,955
