이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Place the hydraulic floor jack under the vehicle until the saddle is directly under the crossmember.
Push downward on the jack's lever to lift the saddle upward so that it contacts the crossmember. Continue pushing downward on the lever to lift the car upward.
Once the car is raised, remove the lug nuts with the ratchet attached to a 3/4'' socket.
Remove the tire off the wheel studs and place it aside.
The wheel studs are the metal bolts sticking out of the wheel hub in the center.
On the same side of the vehicle, go to the rear tire.
Using a ratchet attached to a 3/4" socket, loosen wheel lug nuts. Do not remove them.
Place the floor jack under the frame in front of the rear tire.
Raise the jack until the tire is off the ground.
Remove the rear tire. Roll and place the tire onto the wheel studs on the front wheel.
Tighten the lug nuts using your hand until they are tight.
Roll the previous front tire to the rear and repeat the tightening process
Using a torque wrench, tighten the lug nuts on each wheel to the car manufacturer's recommended torque specification found in the user's manual.
Using an air compressor and the air pressure gauge, fill the front and rear tires to appropriate amount.
다른 6명이 해당 안내서를 완성하였습니다.
댓글 한 개
Really useful and valuable content, Thank you.
<a href="https://highwaypakistan.com/">highway trading comapny</a>
