주요 콘텐츠로 건너뛰기
How to Run MirageOS on TI-NSpire
필요한 것
  1. How to Run MirageOS on TI-NSpire, How to Run MirageOS on TI-NSpire: 1 단계, 이미지 1/2 How to Run MirageOS on TI-NSpire, How to Run MirageOS on TI-NSpire: 1 단계, 이미지 2/2
    • Download the latest version of MirageOS and the latest version of MOSPATCH onto your computer.
    • And if you do not already have it, the TI-NSpire connectivity software.
    • Save the files in a place you can access easily, preferably the desktop.
  2. How to Run MirageOS on TI-NSpire: 2 단계, 이미지 1/1
    • Connect your TI-NSpire to your computer using the TI Calculator Link Cable.
  3. How to Run MirageOS on TI-NSpire: 3 단계, 이미지 1/2 How to Run MirageOS on TI-NSpire: 3 단계, 이미지 2/2
    • Open TI Connect and double click "TI DeviceExplorer."
    • A new window named Device Explorer will open.
  4. How to Run MirageOS on TI-NSpire: 4 단계, 이미지 1/2 How to Run MirageOS on TI-NSpire: 4 단계, 이미지 2/2
    • Highlight the files mospatch.zip and mirageos.zip and drag them into the DeviceExplorer window.
  5. How to Run MirageOS on TI-NSpire: 5 단계, 이미지 1/3 How to Run MirageOS on TI-NSpire: 5 단계, 이미지 2/3 How to Run MirageOS on TI-NSpire: 5 단계, 이미지 3/3
    • Now on your calculator, bring up the catalog by pressing 2nd + 0 (catalog).
    • Press the down arrow key to scroll down to the "Asm(" function (the last item) and press "ENTER".
    • Press PRGM, select MOSPATCH using the arrow keys, and press "ENTER".
  6. How to Run MirageOS on TI-NSpire: 6 단계, 이미지 1/2 How to Run MirageOS on TI-NSpire: 6 단계, 이미지 2/2
    • The calculator should now display "Asm(prgmMOSPATCH".
    • Press "ENTER". The calculator will display "DONE" indicating that you can now run MirageOS on your TI-NSpire!
결론
Now that you have MirageOS running on your TI-NSpire, download some games and try them out! http://www.ticalc.org/pub/83plus/asm/gam...
John Baek
회원 가입일: 09/27/12
31 평판
안내서 4개 작성하였습니다
Cal Poly, Team 7-52, Forte Fall 2012 Cal Poly, Team 7-52, Forte Fall 2012 회원
CPSU-FORTE-F12S7G52
5 회원들
안내서 12개 작성하였습니다
댓글 2개
show an example of running a game. and is the 84 keypad required?
trogfield - 답글
it did not work for me can you help me fix that problem because ive been progaming my own and it did not work so can you find another way because im a big fan of your work it helps me alot
David Fife - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 14
전체 시간: 2,488
