주요 콘텐츠로 건너뛰기
How to fix a Samsung Galaxy S5 that is not charging
필요한 것
  1. How to fix a Samsung Galaxy S5 that is not charging, Check Charging Port: 1 단계, 이미지 1/1
    • Note: Images here are from the internet for reference only but not from me
    • Check the charging port at the bottom of the phone. I used a magnifying glass with light to see because these are very small.
  2. How to fix a Samsung Galaxy S5 that is not charging, Check the pins: 2 단계, 이미지 1/1
    • When I checked the pins in my phone, I saw 3. with the one on the rightmost having 2 layers. This was because one of them was bent making it look like there were only 3 instead of 4
    • I used a needle to push the bent pin. After a few pushes, it started charging again!
    • Reminder: be very careful when pushing the pins. I only did this because my phone was not charging at all and I was ready to get a replacement for the charging port if it still didn't work
결론
다른 10명이 해당 안내서를 완성하였습니다.
SLomat
회원 가입일: 05/16/18
360 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 11
30일 전: 54
전체 시간: 6,119
