주요 콘텐츠로 건너뛰기
How to Securely Anchor and Install a Towel Rack
필요한 것
  1. How to Securely Anchor and Install a Towel Rack, Towel Rack: 1 단계, 이미지 2개 중 1개 How to Securely Anchor and Install a Towel Rack, Towel Rack: 1 단계, 이미지 2개 중 2개
    • Disassemble the mounting bracket by first unscrewing the screw from its side.
  2. How to Securely Anchor and Install a Towel Rack: 2 단계, 이미지 1개 중 1개
    • Place drywall anchors into the holes.
  3. How to Securely Anchor and Install a Towel Rack: 3 단계, 이미지 1개 중 1개
    • Hammer the drywall anchors into the holes.
  4. How to Securely Anchor and Install a Towel Rack: 4 단계, 이미지 2개 중 1개 How to Securely Anchor and Install a Towel Rack: 4 단계, 이미지 2개 중 2개
    • Place the mounting bracket onto the wall making sure that the hole with "UP" next to it is aligned with the top hole. Screw in a screw through the mounting bracket into the drywall anchors.
  5. How to Securely Anchor and Install a Towel Rack: 5 단계, 이미지 1개 중 1개
    • Place the cover over the base of the mounting bracket.
  6. How to Securely Anchor and Install a Towel Rack: 6 단계, 이미지 1개 중 1개
    • Insert the towel rack into the hole of the towel rack holder and place the towel rack holder over the bracket.
  7. How to Securely Anchor and Install a Towel Rack: 7 단계, 이미지 1개 중 1개
    • Secure the towel rack holder into the bracket by screwing the small screw from step 1 into its hole.
결승점
작성자
2다른 기여자 명과 함께
Brenton Reece
회원 가입일: 09/27/24
148 평판
안내서 1개를 작성함
CSU Sacramento, Team 1-10, Laflen Fall 2024 CSU Sacramento, Team 1-10, Laflen Fall 2024 회원
CSUSAC-LAFLEN-F24S1G10
1 회원
안내서 1개 작성
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 26
지난 30일: 78
전체 시간: 503
