주요 콘텐츠로 건너뛰기
How to Sew On A Press Stud
필요한 것
  1. How to Sew On A Press Stud, How to Sew On A Press Stud: 1 단계, 이미지 1개 중 1개
    • Separate the press studs into two halves.
    • The ball
    • The socket
  2. How to Sew On A Press Stud: 2 단계, 이미지 1개 중 1개
    • Gather two and a half feet of thread. Thread the needle.
  3. How to Sew On A Press Stud: 3 단계, 이미지 3개 중 1개 How to Sew On A Press Stud: 3 단계, 이미지 3개 중 2개 How to Sew On A Press Stud: 3 단계, 이미지 3개 중 3개
    • Move the needle to the middle so both sides of the thread are equal lengths.
    • Tie a knot at the end of the thread.
  4. How to Sew On A Press Stud: 4 단계, 이미지 2개 중 1개 How to Sew On A Press Stud: 4 단계, 이미지 2개 중 2개
    • Tie a second knot over the first one.
    • This will make the knot bigger.
  5. How to Sew On A Press Stud: 5 단계, 이미지 1개 중 1개
    • Mark the areas you want to sew the press studs into using a fabric pencil. Make sure the markings are aligned.
    • The ball should be sewn on the inner flap of the top piece.
    • The socket should be sewn on top of the bottom piece
  6. How to Sew On A Press Stud: 6 단계, 이미지 3개 중 1개 How to Sew On A Press Stud: 6 단계, 이미지 3개 중 2개 How to Sew On A Press Stud: 6 단계, 이미지 3개 중 3개
    • Hold down the press stud with your thumb.
    • Poke the needle through only the first layer of the fabric, grabbing only a small bite of the fabric.
    • Push the needle through the hole of the press stud and pull the thread all the way through.
    • If your garment is not double-layered like the one in the guide, the thread will show on the other side.
  7. How to Sew On A Press Stud: 7 단계, 이미지 3개 중 1개 How to Sew On A Press Stud: 7 단계, 이미지 3개 중 2개 How to Sew On A Press Stud: 7 단계, 이미지 3개 중 3개
    • Thread the needle through the fabric next to the first hole you made.
    • Stop before pulling the needle all the way through. There will be a small loop. Thread the needle through the loop and pull.
    • This will create a sturdy knot along the outer rim of the press stud.
  8. How to Sew On A Press Stud: 8 단계, 이미지 2개 중 1개 How to Sew On A Press Stud: 8 단계, 이미지 2개 중 2개
    • Repeat the previous step and continue to sew along the first press stud hole (at least four times total).
    • Make sure the knots made by the loops fall next to each other, not on top.
  9. How to Sew On A Press Stud: 9 단계, 이미지 2개 중 1개 How to Sew On A Press Stud: 9 단계, 이미지 2개 중 2개
    • Once you have completed sewing along the first hole, insert your needle through the fabric of the next hole. Pull the thread all the way through.
    • Repeat Steps 7-9 until you finish sewing through all four holes of the press stud.
  10. How to Sew On A Press Stud: 10 단계, 이미지 3개 중 1개 How to Sew On A Press Stud: 10 단계, 이미지 3개 중 2개 How to Sew On A Press Stud: 10 단계, 이미지 3개 중 3개
    • Once all the holes are sewn through, insert the needle through the thread of the hole you ended on.
    • Pull the thread until you make a small loop. Insert the needle through the loop and pull all the way.
  11. How to Sew On A Press Stud: 11 단계, 이미지 1개 중 1개
    • Cut the excess thread. Your press stud is now completely sewn on!
    • Follow the exact same steps for the socket.
결승점
작성자
2다른 기여자 명과 함께
Emily Pang
회원 가입일: 04/11/21
193 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 14
지난 30일: 63
전체 시간: 4,159
