이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Clamp each side of the tear with a safety pin or binder clamp to ensure it stays tight while you stitch.
Thread the curved upholstery needle with extra long, double length of thread in the same color as your car seat’s fabric. Tie a knot with the ends of the double thread, opposite to the needle.
Slip the needle through the fabric at one end of the tear, and bring it up through the fabric on the other side, about a quarter inch away from the tear.
Bring the needle back over the tear and slip it through the fabric to the other side again, continue this until you reach the end of the tear, keeping the stitches a quarter inch apart .
When you reach the end of the tear, stitch over the last stitch 3-5 times, then knot the edge of the thread and trim it as close as possible to the fabric.
Paint Fray Check on top of the stitches, focusing on the needle holes and tear itself.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 3개
Well said Megan. I 100% agree with you. That is the worst fix example I've seen!
Paula Hall - 답글
Well, it's not pretty, but it's exactly what I was looking for to repair an old, beater pickup truck seat.
