주요 콘텐츠로 건너뛰기
How to Sew Torn Lace
필요한 것
  1. How to Sew Torn Lace, How to Sew Torn Lace: 1 단계, 이미지 3개 중 1개 How to Sew Torn Lace, How to Sew Torn Lace: 1 단계, 이미지 3개 중 2개 How to Sew Torn Lace, How to Sew Torn Lace: 1 단계, 이미지 3개 중 3개
    • Cut a piece of thread around two feet in length.
    • Push the thread through the hole of the sewing needle.
    • Use a thread of matching color to the lace. This guide shows a thread that contrasts with the color of the lace for easier visibility.
    • Pull the thread until the ends meet.
  2. How to Sew Torn Lace: 2 단계, 이미지 3개 중 1개 How to Sew Torn Lace: 2 단계, 이미지 3개 중 2개 How to Sew Torn Lace: 2 단계, 이미지 3개 중 3개
    • Tie two overlapping knots at the end of the thread.
  3. How to Sew Torn Lace: 3 단계, 이미지 1개 중 1개
    • Place your lace on a flat and smooth surface.
  4. How to Sew Torn Lace: 4 단계, 이미지 1개 중 1개
    • Stick a pin near the hole, holding the lace in place.
    • Be careful with your fingers when inserting the pin.
  5. How to Sew Torn Lace: 5 단계, 이미지 3개 중 1개 How to Sew Torn Lace: 5 단계, 이미지 3개 중 2개 How to Sew Torn Lace: 5 단계, 이미지 3개 중 3개
    • Stitch the two sides of the hole together until you reach the end.
    • Keep stitches close together to avoid gaps in your stitch.
    • Be careful of the needle tip when sewing.
  6. How to Sew Torn Lace: 6 단계, 이미지 1개 중 1개
    • Stick the needle through to the back, or inside, of the lace.
    • Be careful of where you hands are placed when sticking the needle through.
  7. How to Sew Torn Lace: 7 단계, 이미지 3개 중 1개 How to Sew Torn Lace: 7 단계, 이미지 3개 중 2개 How to Sew Torn Lace: 7 단계, 이미지 3개 중 3개
    • Tie two overlapping knots to finish the stitch.
    • Keep the knot as close to the lace as possible.
  8. How to Sew Torn Lace: 8 단계, 이미지 3개 중 1개 How to Sew Torn Lace: 8 단계, 이미지 3개 중 2개 How to Sew Torn Lace: 8 단계, 이미지 3개 중 3개
    • Cut off any excess thread at the end of your stitch.
결승점
작성자
2다른 기여자 명과 함께
Joanne Lai
회원 가입일: 11/05/24
157 평판
안내서 1개를 작성함
UC Davis, Team 3-2, Vidal-Chiesa Fall 2024 UC Davis, Team 3-2, Vidal-Chiesa Fall 2024 회원
UCD-VIDAL-CHIESA-F24S3G2
3 회원들
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 61
전체 시간: 371
