주요 콘텐츠로 건너뛰기
How to Sew a Buttonhole by Hand
필요한 것
  1. How to Sew a Buttonhole by Hand, How to Sew a Buttonhole by Hand: 1 단계, 이미지 2개 중 1개 How to Sew a Buttonhole by Hand, How to Sew a Buttonhole by Hand: 1 단계, 이미지 2개 중 2개
    • Place your button where you want the buttonhole.
    • Use a chalk marker or washable fabric marker to make a vertical line just to the right of the button.
    • Use your marker to make a vertical line just to the left of the button.
  2. How to Sew a Buttonhole by Hand: 2 단계, 이미지 1개 중 1개
    • Use your marker to make a horizontal line that connects the two vertical lines.
  3. How to Sew a Buttonhole by Hand: 3 단계, 이미지 3개 중 1개 How to Sew a Buttonhole by Hand: 3 단계, 이미지 3개 중 2개 How to Sew a Buttonhole by Hand: 3 단계, 이미지 3개 중 3개
    • Sew your first stitch from the top to the bottom of the vertical chalk line on the left.
    • Continue by sewing a running line of small stitches underneath the horizontal chalk line, up the right side, then above the horizontal line.
    • This is the outline for the buttonhole.
  4. How to Sew a Buttonhole by Hand: 4 단계, 이미지 3개 중 1개 How to Sew a Buttonhole by Hand: 4 단계, 이미지 3개 중 2개 How to Sew a Buttonhole by Hand: 4 단계, 이미지 3개 중 3개
    • Use a seam ripper to poke a hole in the fabric that is large enough for your scissors.
    • Use your scissors to cut a slit along the horizontal chalk line in the middle of your stitched outline.
  5. How to Sew a Buttonhole by Hand: 5 단계, 이미지 1개 중 1개
    • Slide your button into the slit to make sure it's large enough.
  6. How to Sew a Buttonhole by Hand: 6 단계, 이미지 3개 중 1개 How to Sew a Buttonhole by Hand: 6 단계, 이미지 3개 중 2개 How to Sew a Buttonhole by Hand: 6 단계, 이미지 3개 중 3개
    • Bring your threaded needle up through the slit.
    • Push the needle back down through the fabric just to the outside of your first outline stitch.
    • Bring the needle back up through the slit and continue making a row of small, tight, vertical stitches along the bottom edge of the slit.
  7. How to Sew a Buttonhole by Hand: 7 단계, 이미지 1개 중 1개
    • When you get to the right edge of the slit, continue by making a small row of horizontal stitches around that end of the buttonhole.
  8. How to Sew a Buttonhole by Hand: 8 단계, 이미지 2개 중 1개 How to Sew a Buttonhole by Hand: 8 단계, 이미지 2개 중 2개
    • Working from right to left, continue sewing small, tight, vertical stitches along the top side of the buttonhole slit.
    • When you get to the left edge, make a row of small horizontal stitches around that end, until you arrive back where you began.
    • Push your needle through to the back and tie it off with a knot.
  9. How to Sew a Buttonhole by Hand: 9 단계, 이미지 1개 중 1개
    • Test your new buttonhole and enjoy!
결승점
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Michelle Macias
회원 가입일: 01/18/24
225 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 52
지난 30일: 311
전체 시간: 4,388
