주요 콘텐츠로 건너뛰기
How to Sew a Cloth Seat Cushion Strap
필요한 것
  1. How to Sew a Cloth Seat Cushion Strap, How to Sew a Cloth Seat Cushion Strap: 1 단계, 이미지 2개 중 1개 How to Sew a Cloth Seat Cushion Strap, How to Sew a Cloth Seat Cushion Strap: 1 단계, 이미지 2개 중 2개
    • Find the hole in the seat cushion.
  2. How to Sew a Cloth Seat Cushion Strap: 2 단계, 이미지 2개 중 1개 How to Sew a Cloth Seat Cushion Strap: 2 단계, 이미지 2개 중 2개
    • Cut a piece of thread long enough to fit the hole.
    • Put the thread through the eye of the needle.
  3. How to Sew a Cloth Seat Cushion Strap: 3 단계, 이미지 2개 중 1개 How to Sew a Cloth Seat Cushion Strap: 3 단계, 이미지 2개 중 2개
    • Tie a knot at the end of the thread.
  4. How to Sew a Cloth Seat Cushion Strap: 4 단계, 이미지 1개 중 1개
    • Sandwich the strap in between the two pieces of fabric.
  5. How to Sew a Cloth Seat Cushion Strap: 5 단계, 이미지 1개 중 1개
    • Push the needle from the inside of the cushion, around where the broken seam is.
  6. How to Sew a Cloth Seat Cushion Strap: 6 단계, 이미지 2개 중 1개 How to Sew a Cloth Seat Cushion Strap: 6 단계, 이미지 2개 중 2개
    • Use a small stitch over the material.
    • Pull the needle until thread is taut.
  7. How to Sew a Cloth Seat Cushion Strap: 7 단계, 이미지 2개 중 1개 How to Sew a Cloth Seat Cushion Strap: 7 단계, 이미지 2개 중 2개
    • Use a small stitch under the material.
    • Pull the needle until the thread is taut.
  8. How to Sew a Cloth Seat Cushion Strap: 8 단계, 이미지 1개 중 1개
    • Continue the same alternating stitch pattern of over and under until the end of the hole.
  9. How to Sew a Cloth Seat Cushion Strap: 9 단계, 이미지 2개 중 1개 How to Sew a Cloth Seat Cushion Strap: 9 단계, 이미지 2개 중 2개
    • Push the needle in through the end of the sewn hole.
  10. How to Sew a Cloth Seat Cushion Strap: 10 단계, 이미지 3개 중 1개 How to Sew a Cloth Seat Cushion Strap: 10 단계, 이미지 3개 중 2개 How to Sew a Cloth Seat Cushion Strap: 10 단계, 이미지 3개 중 3개
    • Wrap the thread around the needle two times.
    • Tie off your thread with a knot.
  11. How to Sew a Cloth Seat Cushion Strap: 11 단계, 이미지 1개 중 1개
    • Pull the knot tightly.
  12. How to Sew a Cloth Seat Cushion Strap: 12 단계, 이미지 3개 중 1개 How to Sew a Cloth Seat Cushion Strap: 12 단계, 이미지 3개 중 2개 How to Sew a Cloth Seat Cushion Strap: 12 단계, 이미지 3개 중 3개
    • Push the needle through the side of the cushion.
  13. How to Sew a Cloth Seat Cushion Strap: 13 단계, 이미지 2개 중 1개 How to Sew a Cloth Seat Cushion Strap: 13 단계, 이미지 2개 중 2개
    • Pull until taut and cut off the excess thread.
    • This will hide the excess thread.
  14. How to Sew a Cloth Seat Cushion Strap: 14 단계, 이미지 1개 중 1개
    • Now, your seat cushion is fixed!
결승점
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Deepa Bhat
회원 가입일: 04/25/24
253 평판
안내서 1개를 작성함
UC Davis, Team 3-5, Whithaus Spring 2024 UC Davis, Team 3-5, Whithaus Spring 2024 회원
UCD-WHITHAUS-S24S3G5
3 회원들
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 37
전체 시간: 488
