주요 콘텐츠로 건너뛰기
How to Sew a Hole and reattach zippers to a purse
필요한 것
  1. How to Sew a Hole and reattach zippers to a purse, Hole and Zippers: 1 단계, 이미지 1/1
    • Locate the hole.
    • It’s important to analyze the area and make sure you have enough thread to cover the area; more is always better.
  2. How to Sew a Hole and reattach zippers to a purse: 2 단계, 이미지 1/1
    • Get a needle and thread ready to sew and make a knot at the end of the thread.
  3. How to Sew a Hole and reattach zippers to a purse: 3 단계, 이미지 1/2 How to Sew a Hole and reattach zippers to a purse: 3 단계, 이미지 2/2
    • Sew the hole together.
    • Notice that the fabric looks smooth and straight, this is from folding the frayed parts of the fabric inward to make the sewing process easier.
    • Make sure to end your sewing session with a secured knot, and cut off excess thread.
  4. How to Sew a Hole and reattach zippers to a purse: 4 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Use tweezers to grab one side of the opened coil.
  5. How to Sew a Hole and reattach zippers to a purse: 5 단계, 이미지 1/1
    • Locate the detached zipper slider and turn it backwards.
    • This is done while still holding one side of the opened coil.
  6. How to Sew a Hole and reattach zippers to a purse: 6 단계, 이미지 1/1
    • Place one side of the coil inside the zipper slider just a little using tweezers.
  7. How to Sew a Hole and reattach zippers to a purse: 7 단계, 이미지 1/2 How to Sew a Hole and reattach zippers to a purse: 7 단계, 이미지 2/2
    • Grab the other side of the opened coils and place that side inside the zipper slider.
    • Make sure that each of the coils are placed evenly inside the slider.
  8. How to Sew a Hole and reattach zippers to a purse: 8 단계, 이미지 1/2 How to Sew a Hole and reattach zippers to a purse: 8 단계, 이미지 2/2
    • Once both coils are even, using the zipper “Pull”, slowly slide the “Pull” closing it.
  9. How to Sew a Hole and reattach zippers to a purse: 9 단계, 이미지 1/3 How to Sew a Hole and reattach zippers to a purse: 9 단계, 이미지 2/3 How to Sew a Hole and reattach zippers to a purse: 9 단계, 이미지 3/3
    • Repeat steps 4 to 9 for the other zipper wrapping up the coil process and being able to close both zippers.
결론
다른 2명이 해당 안내서를 완성하였습니다.
ReNieka Perry
회원 가입일: 01/21/18
223 평판
안내서 1개 작성함
USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2018 USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2018 회원
USFSM-STEWART-S18S1G1
15 회원들
안내서 26개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 7
7일 전: 16
30일 전: 83
전체 시간: 1,998
