주요 콘텐츠로 건너뛰기
How to Sharpen Troy-Bilt TB110 Lawnmower Blades
필요한 것
  1. How to Sharpen Troy-Bilt TB110 Lawnmower Blades, How to Sharpen Troy-Bilt TB110 Lawnmower Blades: 1 단계, 이미지 1/2 How to Sharpen Troy-Bilt TB110 Lawnmower Blades, How to Sharpen Troy-Bilt TB110 Lawnmower Blades: 1 단계, 이미지 2/2
    • Disconnect the spark plug wire.
    • This step is critical to avoid an accidental startup since we are working on the blade.
  2. How to Sharpen Troy-Bilt TB110 Lawnmower Blades: 2 단계, 이미지 1/2 How to Sharpen Troy-Bilt TB110 Lawnmower Blades: 2 단계, 이미지 2/2
    • Put saran wrap on the inside of the gas cap.
    • This is done to prevent gas from spilling out when we turn over the lawnmower.
  3. How to Sharpen Troy-Bilt TB110 Lawnmower Blades: 3 단계, 이미지 1/1
    • Turn the lawn mower over on its side.
  4. How to Sharpen Troy-Bilt TB110 Lawnmower Blades: 4 단계, 이미지 1/2 How to Sharpen Troy-Bilt TB110 Lawnmower Blades: 4 단계, 이미지 2/2
    • Use a 5/8 ratchet or wrench to remove the bolt. Then remove the blade.
    • Note how the blade is oriented on the lawn mower for reassembly.
    • Do not grab it from the sharp parts of the blade.
  5. How to Sharpen Troy-Bilt TB110 Lawnmower Blades: 5 단계, 이미지 1/1
    • Clean the blade with a scraper or a wire brush to remove grass residue .
  6. How to Sharpen Troy-Bilt TB110 Lawnmower Blades: 6 단계, 이미지 1/1
    • Secure the blade in a vice.
  7. How to Sharpen Troy-Bilt TB110 Lawnmower Blades: 7 단계, 이미지 1/2 How to Sharpen Troy-Bilt TB110 Lawnmower Blades: 7 단계, 이미지 2/2
    • Sharpen the blade with a file or with a grinder. Follow the angle that is already established and move the file along until the edge becomes sharp.
    • Be carful when checking for sharpness. You can very gently run your finger along the edge to check.
    • The blade does not need to be as sharp as a razor blade. Try to make it as sharp as pair of scissors. Check the lawnmower for specific details.
  8. How to Sharpen Troy-Bilt TB110 Lawnmower Blades: 8 단계, 이미지 1/2 How to Sharpen Troy-Bilt TB110 Lawnmower Blades: 8 단계, 이미지 2/2
    • Put the blade back onto the lawn mower and screw the bolt back on while safely securing the blade.
    • Again be careful not to hold the blade by the sharp edges.
  9. How to Sharpen Troy-Bilt TB110 Lawnmower Blades: 9 단계, 이미지 1/2 How to Sharpen Troy-Bilt TB110 Lawnmower Blades: 9 단계, 이미지 2/2
    • Flip the lawn mower back to the upright position and remove the saran wrap from the gas cap.
    • Plug the spark plug wire in until you hear a click.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Andrew DePari
회원 가입일: 03/24/21
193 평판
안내서 1개 작성함
UMass Dartmouth, Team S1-G7, O'Connell Spring 2021 UMass Dartmouth, Team S1-G7, O'Connell Spring 2021 회원
UMASSD-O'CONNELL-S21S1G7
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 16
30일 전: 47
전체 시간: 1,124
