주요 콘텐츠로 건너뛰기
How to Sharpen a Dull Chisel
필요한 것
  1. How to Sharpen a Dull Chisel, How to Sharpen a Dull Chisel: 1 단계, 이미지 1개 중 1개
    • Use water or a mild cleaning solution with a rag or sponge to remove any grime or dirt from the chisel.
    • This helps expose any rust or damage and prevents debris from interfering with sharpening later.
  2. How to Sharpen a Dull Chisel: 2 단계, 이미지 1개 중 1개
    • Next apply WD40 lubricant around any rusted areas before moving on to the next step.
    • Scraping dry rust can damage the metal and make the process unnecessarily difficult.
  3. How to Sharpen a Dull Chisel: 3 단계, 이미지 1개 중 1개
    • Use a brass wire brush to scrub the rusted areas.
    • Focus especially on the blade and any areas that will contact the sharpening stone.
    • Use caution with the wire brush, as its sharp bristles can cause injury.
  4. How to Sharpen a Dull Chisel: 4 단계, 이미지 1개 중 1개
    • Use a clean rag to remove any leftover WD-40 or rust residue.
    • This is important — if oil stays on the blade, it can make your sharpening stone less effective by repelling water.
  5. How to Sharpen a Dull Chisel: 5 단계, 이미지 2개 중 1개 How to Sharpen a Dull Chisel: 5 단계, 이미지 2개 중 2개
    • Soak the wet sharpening stone with water for a couple of minutes and place it on a flat surface.
    • Hold the chisel at a 20-degree angle and push it forward against the stone to grind the edge. After each stroke, lift the chisel and return it to the starting position.
    • Repeat this motion on both sides of the stone until the chisel reaches your desired sharpness.
    • Water acts as a lubricant, helping to carry away metal particles and prevent clogging during sharpening.
  6. How to Sharpen a Dull Chisel: 6 단계, 이미지 2개 중 1개 How to Sharpen a Dull Chisel: 6 단계, 이미지 2개 중 2개
    • With a rag, carefully wipe of any debris and metal shaving possible left on the chisel.
    • Apply a small amount of WD-40 to protect the metal from rust.
    • Keep in mind that this is only a temporary measure.
    • Use caution—this blade is now significantly sharper.
결론
After you follow all these steps, you should have a nice, clean chisel
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Christine Vu
회원 가입일: 03/04/25
142 평판
안내서 1개를 작성함
CSU Los Angeles, Team 3-10, Grodsky Spring 2025 CSU Los Angeles, Team 3-10, Grodsky Spring 2025 회원
CSULA-GRODSKY-S25S3G10
2 회원들
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 11
전체 시간: 131
