주요 콘텐츠로 건너뛰기
How to Shorten a Belt
필요한 것
  1. How to Shorten a Belt, Measure the Belt: 1 단계, 이미지 1개 중 1개
    • Put your belt on.
    • Using a ruler or measuring tape, measure how much of the belt you want to remove. Make this mark on the buckle end of the belt.
    • Place a mark where you will cut the belt to shorten it.
  2. How to Shorten a Belt: 2 단계, 이미지 2개 중 1개 How to Shorten a Belt: 2 단계, 이미지 2개 중 2개
    • Measure how much of the belt is folded over the belt. Add that length to the cut mark to leave enough material to fold over the buckle.
    • Using a screwdriver, remove all screws from the buckle end of the belt.
  3. How to Shorten a Belt: 3 단계, 이미지 1개 중 1개
    • Using scissors, cut on the exact spot of your new mark.
    • You can round the edges of the cut to make the belt tip look neat.
    • You can add shoe or leather polish to the cut mark to ensure it is the same color as the belt.
  4. How to Shorten a Belt, Reassembling the Belt: 4 단계, 이미지 3개 중 1개 How to Shorten a Belt, Reassembling the Belt: 4 단계, 이미지 3개 중 2개 How to Shorten a Belt, Reassembling the Belt: 4 단계, 이미지 3개 중 3개
    • Reinsert the screws and screw them back in place using a screwdriver.
  5. How to Shorten a Belt, Add New Buckle Holes to the Belt: 5 단계, 이미지 2개 중 1개 How to Shorten a Belt, Add New Buckle Holes to the Belt: 5 단계, 이미지 2개 중 2개
    • Place your belt on a workspace that can be nailed into.
    • Place a nail on the new spot where you'd like to add a hole.
    • Hammer the nail until it goes all the way through the belt.
    • Caution: Be careful when using a hammer.
  6. How to Shorten a Belt: 6 단계, 이미지 2개 중 1개 How to Shorten a Belt: 6 단계, 이미지 2개 중 2개
    • Try on the belt and see if it fits comfortably.
    • If not, follow this guide again to add more holes.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Uvaldo Chan
회원 가입일: 04/12/21
154 평판
안내서 1개를 작성함
CSU Los Angeles, Team S1-G7, Harris Spring 2021 CSU Los Angeles, Team S1-G7, Harris Spring 2021 회원
CSULA-HARRIS-S21S1G7
2 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 12
지난 30일: 78
전체 시간: 2,859
