주요 콘텐츠로 건너뛰기
How to Shorten a Watch Band
필요한 것
  1. How to Shorten a Watch Band, How to Shorten a Watch Band: 1 단계, 이미지 1/1
    • Open the watch band.
  2. How to Shorten a Watch Band: 2 단계, 이미지 1/1
    • Find the arrows inside the band and place the watch so the arrows are facing down.
  3. How to Shorten a Watch Band: 3 단계, 이미지 1/1
    • Place a nail in the hole on the opposite side of the arrow.
    • Gently tap the nail into the hole with a small hammer.
  4. How to Shorten a Watch Band: 4 단계, 이미지 1/1
    • Remove the pin from the hole of the watch link.
    • Remove the watch link.
  5. How to Shorten a Watch Band: 5 단계, 이미지 1/2 How to Shorten a Watch Band: 5 단계, 이미지 2/2
    • Repeat Steps 3 and 4 until the watch band is the desired size.
  6. How to Shorten a Watch Band: 6 단계, 이미지 1/2 How to Shorten a Watch Band: 6 단계, 이미지 2/2
    • Join the clock's bands and insert the pin in the same direction as the arrow until it is sealed.
결승점
다른 6명이 해당 안내서를 완성하였습니다.
Yedsmarie Pesante
회원 가입일: 10/06/21
277 평판
안내서 1개 작성함
댓글 한 개
Never knew how easy it was until I went through this guide. Appreciate how simple you made it
Thomas Legrand - 답글
댓글 쓰기
조회 통계:
24 시간 전: 9
7일 전: 63
30일 전: 243
전체 시간: 20,826
