주요 콘텐츠로 건너뛰기
How to Shorten the Length of Pyjama Pants
필요한 것
  1. How to Shorten the Length of Pyjama Pants, How to Shorten the Length of Pyjama Pants: 1 단계, 이미지 1개 중 1개
    • Press the pyjamas with an iron to ensure there are no creases.
    • Be careful while using the iron to avoid any burns.
  2. How to Shorten the Length of Pyjama Pants: 2 단계, 이미지 1개 중 1개
    • Take some fabric chalk and measuring tape, then measure the desired length and then make marks on each leg as follows:
    • The left line indicates the desired length line.
    • The right line indicates the one inch line for the new hem you'll be creating.
  3. How to Shorten the Length of Pyjama Pants: 3 단계, 이미지 1개 중 1개
    • Use scissors to remove fabric below the lower one inch line created from the chalk marks to shorten the length. Do this for each pant leg.
  4. How to Shorten the Length of Pyjama Pants: 4 단계, 이미지 3개 중 1개 How to Shorten the Length of Pyjama Pants: 4 단계, 이미지 3개 중 2개 How to Shorten the Length of Pyjama Pants: 4 단계, 이미지 3개 중 3개
    • Take a needle and about 30 inches of thread and put the thread through the needle, then immediately tie the thread off.
    • Be careful with the needle as minor injury may occur if not handled carefully.
  5. How to Shorten the Length of Pyjama Pants: 5 단계, 이미지 3개 중 1개 How to Shorten the Length of Pyjama Pants: 5 단계, 이미지 3개 중 2개 How to Shorten the Length of Pyjama Pants: 5 단계, 이미지 3개 중 3개
    • Fold the pyjama from the one inch extra line so the desired length is achieved, and then hem with the needle.
    • The needle needs to pass through both layers of the folded fabric to start the hemming process.
    • Do this for each pyjama leg.
    • There should be at least 45 stitches on each pyjama leg.
  6. How to Shorten the Length of Pyjama Pants: 6 단계, 이미지 3개 중 1개 How to Shorten the Length of Pyjama Pants: 6 단계, 이미지 3개 중 2개 How to Shorten the Length of Pyjama Pants: 6 단계, 이미지 3개 중 3개
    • At the end of the hem, take the needle through the thread three times to secure the stitch.
결론
Congratulations; you did it!
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Aisha Freed
회원 가입일: 07/03/22
211 평판
안내서 1개를 작성함
1가이드 댓글
It is a great and clear repair guide! You shot good photos for every step. Your actions were all well-captured in the photos by using the flip-book style. Properly use of markup also made the guide easier to understand. Also, all the instructions described the actions clearly so it is easy to follow.
Great work!
Cheuk Wai Chan - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 21
지난 30일: 88
전체 시간: 4,556
