주요 콘텐츠로 건너뛰기
How to Shrink a Tennis Racket Grip
필요한 것
  1. How to Shrink a Tennis Racket Grip, Remove Grip Tape: 1 단계, 이미지 1개 중 1개
    • Pull the tape until it comes off of the grip.
    • Use a sharp object to cut it off if needed.
  2. How to Shrink a Tennis Racket Grip, Remove the Overgrip: 2 단계, 이미지 2개 중 1개 How to Shrink a Tennis Racket Grip, Remove the Overgrip: 2 단계, 이미지 2개 중 2개
    • If your racket does not have an overgrip on it, then skip this step.
    • There is a good chance it is sticky.
  3. How to Shrink a Tennis Racket Grip, Put the Overgrip at the Bottom of the Handle: 3 단계, 이미지 1개 중 1개
    • Attach the smaller end of the new overgrip to the bottom of the handle.
    • Wrap the overgrip around the handle, parallel to the bottom of the grip.
  4. How to Shrink a Tennis Racket Grip, Wrap the Overgrip around the Handle: 4 단계, 이미지 1개 중 1개
    • Pull the grip tightly, leaving little to no open areas between the different parts of the overgrip.
    • Leave a little overlap between each row of your grip.
    • Most of your overgrip should cover the handle instead of a lower row of overgrip.
    • Make each row as close to the same size as possible.
  5. How to Shrink a Tennis Racket Grip, Put on the Tape: 5 단계, 이미지 2개 중 1개 How to Shrink a Tennis Racket Grip, Put on the Tape: 5 단계, 이미지 2개 중 2개
    • It should tie the end of the grip to the rest of the racket.
    • I did not cut the end of the overgrip with scissors. If you want the grip to fit better, cut the end of the overgrip off at a 45 degree angle.
결론
If you decide that you want to go back to the racket grip's original size, then you need to remove the overgrip and put on a replacement grip.
작성자
2다른 기여자 명과 함께
Jim Watkins
회원 가입일: 10/01/23
133 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 21
전체 시간: 266
