주요 콘텐츠로 건너뛰기
How to Spot-wash Clothing
필요한 것
  1. How to Spot-wash Clothing, How to Spot-wash Clothing: 1 단계, 이미지 1/2 How to Spot-wash Clothing, How to Spot-wash Clothing: 1 단계, 이미지 2/2
    • Examine the stain. Determine what cleaning agent you'll need using our Stain Removal page. For general dirt, use a gentle, low-chemical liquid laundry soap.
    • Hold the garment over the sink and rub a small amount of your cleaning agent into the stain with your finger.
    • If you are dealing with a tricky stain, follow the instructions on the Stain Removal page linked above.
  2. How to Spot-wash Clothing: 2 단계, 이미지 1/2 How to Spot-wash Clothing: 2 단계, 이미지 2/2
    • Using a toothbrush, gently work the cleaning agent into the stain.
    • Use an up-and-down motion with the brush—tapping the stain with the bristles—as opposed to a back-and-forth motion which can damage the fibers of the garment.
    • If you are working with a knitted garment, such as a sweater, do not stretch the garment as you are cleaning it as this can cause warping of the fibers.
    • Work the stain out of the garment. If the stain isn't releasing, check out the Stain Removal page for help on your particular stain.
  3. How to Spot-wash Clothing: 3 단계, 이미지 1/1
    • Rinse the spot throughly with cold water.
    • For quicker drying, try to keep the water contained to a small area surrounding the stain.
    • If you are working on a knitted garment, such as a sweater, do not use hot water as it can shrink the fibers. In general, cold water is better for cleaning garments. The water from your sink is not hot enough to sanitize garments, so cold water works just as well.
  4. How to Spot-wash Clothing: 4 단계, 이미지 1/2 How to Spot-wash Clothing: 4 단계, 이미지 2/2
    • Lay a towel out on a waterproof surface.
    • With the wet area facing up, place your garment on the towel and allow it to dry.
결승점
다른 6명이 해당 안내서를 완성하였습니다.
Brittany McCrigler
회원 가입일: 03/05/12
89,014 평판
안내서 131개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,817개 작성하였습니다
댓글 12개
Senate Cleaning is committed to providing clients with the best office cleaning services in Maryland, Washington, and northern Virginia areas. Through our skillful approach to office cleaning ensures that you will always receive the best value for your money with 100% satisfaction guaranteed
andy - 답글
A good spot cleaner can save a co-worker from an embarrassing moment as they head to a meeting and even avoid or delay a trip to the dry cleaner for overall cleaning. Spot cleaning is often done on intricate clothing, such as a beaded dress .
Acs Cleaning - 답글
With help of Spot cleaning, we can easily clean clothing. You can also clean your office with help of our office cleaners Office Cleaning.
Japs Cleaning - 답글
I am very delighted in for this blog. Its a useful article for my office cleaning melbourne. It help me particularly to take care of certain issues. Its chance are so phenomenal and working style so speedy. Thanks. Regards,
mary Stella - 답글
Japs Cleaning Services is a well-known company that offers ***Office Cleaners in Melbourne*** in order to aid daily commercial clients in maintaining clean and comfortable offices.
Kevin Roots - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 15
30일 전: 65
전체 시간: 28,433
