주요 콘텐츠로 건너뛰기
How to Stabilize the Stem of a Longwise ES06 E-Scooter
필요한 것
  1. How to Stabilize the Stem of a Longwise ES06 E-Scooter, How to Stabilize the Stem of a Longwise ES06 E-Scooter: 1 단계, 이미지 1/2 How to Stabilize the Stem of a Longwise ES06 E-Scooter, How to Stabilize the Stem of a Longwise ES06 E-Scooter: 1 단계, 이미지 2/2
    • Power off your E-Scooter and make sure it is not charging.
  2. How to Stabilize the Stem of a Longwise ES06 E-Scooter: 2 단계, 이미지 1/2 How to Stabilize the Stem of a Longwise ES06 E-Scooter: 2 단계, 이미지 2/2
    • Slide the locking clip out from the base of the stem.
    • Unlock the clamp on the stem.
  3. How to Stabilize the Stem of a Longwise ES06 E-Scooter: 3 단계, 이미지 1/2 How to Stabilize the Stem of a Longwise ES06 E-Scooter: 3 단계, 이미지 2/2
    • Gently lower the stem onto the back wheel and keep it stable.
  4. How to Stabilize the Stem of a Longwise ES06 E-Scooter: 4 단계, 이미지 1/3 How to Stabilize the Stem of a Longwise ES06 E-Scooter: 4 단계, 이미지 2/3 How to Stabilize the Stem of a Longwise ES06 E-Scooter: 4 단계, 이미지 3/3
    • Using an adjustable wrench, carefully tighten the bolt at the base of the stem.
    • This will make the stem stable.
    • Do not use the wrench on the spring between the stem and the bolt as it may damage the wires beneath.
  5. How to Stabilize the Stem of a Longwise ES06 E-Scooter: 5 단계, 이미지 1/3 How to Stabilize the Stem of a Longwise ES06 E-Scooter: 5 단계, 이미지 2/3 How to Stabilize the Stem of a Longwise ES06 E-Scooter: 5 단계, 이미지 3/3
    • Using a slotted/flathead screwdriver, carefully tighten the screw on the clamp.
    • This will prevent the clamp from popping open.
  6. How to Stabilize the Stem of a Longwise ES06 E-Scooter: 6 단계, 이미지 1/2 How to Stabilize the Stem of a Longwise ES06 E-Scooter: 6 단계, 이미지 2/2
    • Use a Phillips #0 to tighten the screw on the locking clip.
    • This helps the clamp to stay in place and prevent it from popping open.
결론
Maithili Admane
회원 가입일: 09/24/22
133 평판
안내서 1개 작성함
York University, Team B-3, Allen Fall 2022 York University, Team B-3, Allen Fall 2022 회원
YORK-ALLEN-F22SBG3
2 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 12
30일 전: 50
전체 시간: 685
