소개
If you have a tear on the seam of your t-shirt, use this guide to patch up the tear. Before you begin, turn the shirt inside out and spread out the shirt evenly on a flat surface to get a better look at how large the hole is. Having steady hands is recommended. Be careful of the needles as they can be a little sharp and can poke you. If you want to save your shirt and wear it as many times as you like, then this is the repair for you. This guide demonstrates simple sewing techniques for a fast and easy sewing repair.
필요한 것
Turn the shirt inside out. This will ensure the new seam is sewn on the inside of the shirt.
Once completed, take the needle and thread back to the first stitch.
Insert the needle through the first stitch until the thread has made a small loop outside of the seam.
Insert the needle through the small loop and pull tightly.
Repeat this step to secure the stitching from unraveling and cut the thread as close to the new seam as possible.
