주요 콘텐츠로 건너뛰기
How to Straighten a Kinked Jump Rope
필요한 것
  1. How to Straighten a Kinked  Jump Rope, Prepare the repair area: 1 단계, 이미지 3개 중 1개 How to Straighten a Kinked  Jump Rope, Prepare the repair area: 1 단계, 이미지 3개 중 2개 How to Straighten a Kinked  Jump Rope, Prepare the repair area: 1 단계, 이미지 3개 중 3개
    • Prepare all the tools needed for the repair.
  2. How to Straighten a Kinked  Jump Rope, Fill in the hot water: 2 단계, 이미지 3개 중 1개 How to Straighten a Kinked  Jump Rope, Fill in the hot water: 2 단계, 이미지 3개 중 2개 How to Straighten a Kinked  Jump Rope, Fill in the hot water: 2 단계, 이미지 3개 중 3개
    • Fill the bucket with hot water and gently insert the jump rope.
    • Leave it fully submerged for 3 minutes.
    • Tip: The hot water might cool down so it is always better to have backup water in a kettle to keep refilling the bucket.
  3. How to Straighten a Kinked  Jump Rope, Prepare the jump rope: 3 단계, 이미지 3개 중 1개 How to Straighten a Kinked  Jump Rope, Prepare the jump rope: 3 단계, 이미지 3개 중 2개 How to Straighten a Kinked  Jump Rope, Prepare the jump rope: 3 단계, 이미지 3개 중 3개
    • Use a spoon to remove the jump rope from the water.
    • Tip: Avoid touching the water as it might still be hot.
  4. How to Straighten a Kinked  Jump Rope, Straighten the rope: 4 단계, 이미지 3개 중 1개 How to Straighten a Kinked  Jump Rope, Straighten the rope: 4 단계, 이미지 3개 중 2개 How to Straighten a Kinked  Jump Rope, Straighten the rope: 4 단계, 이미지 3개 중 3개
    • Put the rope under your foot and press it against the floor.
    • Pull the rope upwards in a straight and vertical motion, following the green arrow.
    • Hold onto the grips and firmly push the rope upwards following the red arrows.
    • Keep on holding the rope tight for 3 minutes.
  5. How to Straighten a Kinked  Jump Rope, Finished and ready!: 5 단계, 이미지 2개 중 1개 How to Straighten a Kinked  Jump Rope, Finished and ready!: 5 단계, 이미지 2개 중 2개
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
결론
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
작성자
1다른 기여자 명과 함께
Ben Blischke
회원 가입일: 07/19/23
10,230 평판
안내서 66개를 작성함
INTERSPORT INTERSPORT 회원
Community
25 회원들
안내서 169개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 14
지난 30일: 57
전체 시간: 511
