주요 콘텐츠로 건너뛰기
How to Strip and Recoat a Cast Iron Skillet
필요한 것
  1. How to Strip and Recoat a Cast Iron Skillet, How to Replace a Cast Iron Skillet Coating: 1 단계, 이미지 3개 중 1개 How to Strip and Recoat a Cast Iron Skillet, How to Replace a Cast Iron Skillet Coating: 1 단계, 이미지 3개 중 2개 How to Strip and Recoat a Cast Iron Skillet, How to Replace a Cast Iron Skillet Coating: 1 단계, 이미지 3개 중 3개
    • Clamp down opposite sides of the cast iron skillet to a table.
    • Make sure the clamps are secure to avoid injury.
  2. How to Strip and Recoat a Cast Iron Skillet: 2 단계, 이미지 3개 중 1개 How to Strip and Recoat a Cast Iron Skillet: 2 단계, 이미지 3개 중 2개 How to Strip and Recoat a Cast Iron Skillet: 2 단계, 이미지 3개 중 3개
    • Grind off the black coating of the entire surface to expose the shiny bare metal.
    • Make sure to have on all your safety equipment for this process.
  3. How to Strip and Recoat a Cast Iron Skillet: 3 단계, 이미지 3개 중 1개 How to Strip and Recoat a Cast Iron Skillet: 3 단계, 이미지 3개 중 2개 How to Strip and Recoat a Cast Iron Skillet: 3 단계, 이미지 3개 중 3개
    • Sand the entire surface of the cast iron skillet to smooth any rough spots left.
  4. How to Strip and Recoat a Cast Iron Skillet: 4 단계, 이미지 2개 중 1개 How to Strip and Recoat a Cast Iron Skillet: 4 단계, 이미지 2개 중 2개
    • Rinse the cast iron skillet with water.
    • Scrub the cast iron skillet with a sponge to remove any excess metal shavings.
  5. How to Strip and Recoat a Cast Iron Skillet: 5 단계, 이미지 2개 중 1개 How to Strip and Recoat a Cast Iron Skillet: 5 단계, 이미지 2개 중 2개
    • Apply an even coating of high heat oil to every part of your cast iron skillet.
  6. How to Strip and Recoat a Cast Iron Skillet: 6 단계, 이미지 2개 중 1개 How to Strip and Recoat a Cast Iron Skillet: 6 단계, 이미지 2개 중 2개
    • Wrap the bottom rack of the oven with aluminum foil.
    • Place the cast iron skillet upside down on the rack above the foil.
    • Bake for 1 hour in a preheated oven of 500°F (260°C) or whatever the highest temperature your oven reaches.
    • Let the cast iron skillet cool completely after baking.
  7. How to Strip and Recoat a Cast Iron Skillet: 7 단계, 이미지 3개 중 1개 How to Strip and Recoat a Cast Iron Skillet: 7 단계, 이미지 3개 중 2개 How to Strip and Recoat a Cast Iron Skillet: 7 단계, 이미지 3개 중 3개
    • Repeat steps 5 and 6 until a dark black coating has formed.
결론
The finished product will be a dark black that resembles a non-stick coating and has no sticky patches.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Taylor Krebs
회원 가입일: 02/22/22
208 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 12
지난 30일: 57
전체 시간: 4,192
