주요 콘텐츠로 건너뛰기
How to Take in a Dress by Hand
필요한 것
  1. How to Take in a Dress by Hand, How to Take in a Dress by Hand: 1 단계, 이미지 1/1
    • Lay the dress flat on a table.
  2. How to Take in a Dress by Hand: 2 단계, 이미지 1/2 How to Take in a Dress by Hand: 2 단계, 이미지 2/2
    • Measure the bust and waist of the dress with the measuring tape and write the measurements down.
    • Measure your own bust and waist. Subtract the your measurements from the dress measurements.
    • Divide these numbers by two.
    • This is the amount of fabric that will be removed from each side.
  3. How to Take in a Dress by Hand: 3 단계, 이미지 1/1
    • Turn the dress inside out.
    • Use the marker to mark the amount of bust and waist fabric that you are taking in for both sides.
  4. How to Take in a Dress by Hand: 4 단계, 이미지 1/1
    • Connect the marks with sewing pins (or safety pins) to make a clear path to sew along.
  5. How to Take in a Dress by Hand: 5 단계, 이미지 1/3 How to Take in a Dress by Hand: 5 단계, 이미지 2/3 How to Take in a Dress by Hand: 5 단계, 이미지 3/3
    • Thread the needle and leave plenty of excess thread for tying knots.
    • Start at the bottom of the new hem and weave the needle in and out of the dress until you reach the other side.
    • Tie a few knots at the end and cut the excess thread.
    • Now the new hem has been made.
  6. How to Take in a Dress by Hand: 6 단계, 이미지 1/3 How to Take in a Dress by Hand: 6 단계, 이미지 2/3 How to Take in a Dress by Hand: 6 단계, 이미지 3/3
    • Cut off the excess fabric with the fabric scissors. Stay about a centimeter away from the sewed line to make sure you do not cut the thread.
  7. How to Take in a Dress by Hand: 7 단계, 이미지 1/2 How to Take in a Dress by Hand: 7 단계, 이미지 2/2
    • Repeat all of the previous steps on the other side of the dress.
    • Turn your dress inside right, and that completes this guide.
결승점
Olivia Collins
회원 가입일: 03/23/21
145 평판
안내서 1개 작성함
UMass Dartmouth, Team S1-G7, Gulbrandsen Spring 2021 UMass Dartmouth, Team S1-G7, Gulbrandsen Spring 2021 회원
UMASSD-GULBRANDSEN-S21S1G7
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 47
30일 전: 245
전체 시간: 8,662
