주요 콘텐츠로 건너뛰기
How to Take in a Dress by Hand
필요한 것
  1. How to Take in a Dress by Hand, How to Take in a Dress by Hand: 1 단계, 이미지 1개 중 1개
    • Lay the dress flat on a table.
  2. How to Take in a Dress by Hand: 2 단계, 이미지 2개 중 1개 How to Take in a Dress by Hand: 2 단계, 이미지 2개 중 2개
    • Measure the bust and waist of the dress with the measuring tape and write the measurements down.
    • Measure your own bust and waist. Subtract the your measurements from the dress measurements.
    • Divide these numbers by two.
    • This is the amount of fabric that will be removed from each side.
  3. How to Take in a Dress by Hand: 3 단계, 이미지 1개 중 1개
    • Turn the dress inside out.
    • Use the marker to mark the amount of bust and waist fabric that you are taking in for both sides.
  4. How to Take in a Dress by Hand: 4 단계, 이미지 1개 중 1개
    • Connect the marks with sewing pins (or safety pins) to make a clear path to sew along.
  5. How to Take in a Dress by Hand: 5 단계, 이미지 3개 중 1개 How to Take in a Dress by Hand: 5 단계, 이미지 3개 중 2개 How to Take in a Dress by Hand: 5 단계, 이미지 3개 중 3개
    • Thread the needle and leave plenty of excess thread for tying knots.
    • Start at the bottom of the new hem and weave the needle in and out of the dress until you reach the other side.
    • Tie a few knots at the end and cut the excess thread.
    • Now the new hem has been made.
  6. How to Take in a Dress by Hand: 6 단계, 이미지 3개 중 1개 How to Take in a Dress by Hand: 6 단계, 이미지 3개 중 2개 How to Take in a Dress by Hand: 6 단계, 이미지 3개 중 3개
    • Cut off the excess fabric with the fabric scissors. Stay about a centimeter away from the sewed line to make sure you do not cut the thread.
  7. How to Take in a Dress by Hand: 7 단계, 이미지 2개 중 1개 How to Take in a Dress by Hand: 7 단계, 이미지 2개 중 2개
    • Repeat all of the previous steps on the other side of the dress.
    • Turn your dress inside right, and that completes this guide.
결승점
작성자
1다른 기여자 명과 함께
Olivia Collins
회원 가입일: 03/23/21
145 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 14
지난 30일: 74
전체 시간: 10,574
