주요 콘텐츠로 건너뛰기
How to Tension the Barreto Trencher E718MTH4S 2016 Chain
필요한 것
  1. How to Tension the Barreto Trencher E718MTH4S 2016 Chain, Engage the hub lock pins: 1 단계, 이미지 1/3 How to Tension the Barreto Trencher E718MTH4S 2016 Chain, Engage the hub lock pins: 1 단계, 이미지 2/3 How to Tension the Barreto Trencher E718MTH4S 2016 Chain, Engage the hub lock pins: 1 단계, 이미지 3/3
    • Make sure that both ignition switches are turned to the off position. There is one on the engine and one on the control panel.
    • Pull the ring near one of the wheel hubs straight out, away from the wheel.
    • Rotate it so that the small roll pin lines up with its slot.
    • Release the ring so that the lock pin slides into the wheel. You may need to rotate the wheels a little before the lock pin fully engages.
    • With the pin engaged, it should be very hard to turn the wheels.
    • Repeat this step so that the lock pins on both wheels are engaged.
  2. How to Tension the Barreto Trencher E718MTH4S 2016 Chain, Loosen the adjuster screw locknut: 2 단계, 이미지 1/2 How to Tension the Barreto Trencher E718MTH4S 2016 Chain, Loosen the adjuster screw locknut: 2 단계, 이미지 2/2
    • Make sure the boom is in a horizontal position.
    • Use a 3/4 inch open-end wrench to loosen the adjuster screw locknut so that you have enough space to tighten the adjuster screw as needed.
  3. How to Tension the Barreto Trencher E718MTH4S 2016 Chain, Adjust the chain tension: 3 단계, 이미지 1/3 How to Tension the Barreto Trencher E718MTH4S 2016 Chain, Adjust the chain tension: 3 단계, 이미지 2/3 How to Tension the Barreto Trencher E718MTH4S 2016 Chain, Adjust the chain tension: 3 단계, 이미지 3/3
    • Use a 1/2 inch open-end wrench to tighten or loosen the adjuster screw.
    • Adjust the screw until there is about a 1 inch gap (3.8 cm, or about two fingers wide) between the bottom of the boom and the lowest part of the top of the chain.
  4. How to Tension the Barreto Trencher E718MTH4S 2016 Chain, Tighten the adjuster screw locknut: 4 단계, 이미지 1/2 How to Tension the Barreto Trencher E718MTH4S 2016 Chain, Tighten the adjuster screw locknut: 4 단계, 이미지 2/2
    • After the chain is properly tensioned, use a 3/4 inch open-end wrench to tighten the adjuster screw locknut.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
Adam O'Camb
회원 가입일: 04/11/15
196,689 평판
안내서 416개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 22
30일 전: 76
전체 시간: 3,805
