소개
I used coconutBattery version 3.7 for this guide. I will update this guide if the UI changes in the future.
  1. To get a copy of coconutBattery, head on over to the site I have included below.
    • To get a copy of coconutBattery, head on over to the site I have included below.
    • Hit that download button. It should be downloading into wherever you set your downloads to download to.
    • Download coconutBattery here.
  2. Lucky us! coconutBattery is already ready to run after being downloaded.
    • Lucky us! coconutBattery is already ready to run after being downloaded.
    • Double click on the coconutBattery application.
      • The location of where you have saved the coconutBattery application may vary. For me, I saved it to my Downloads folder.
  3. US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  4. All done! You can now see...
    • All done! You can now see...
    • Your Mac's info...
    • Your Battery info...
    • And lastly, your charger's info.
    • If you have been sent here by a user on the Answers Forum or are going to ask a question about your Mac's battery on the answers forum, take a screenshot of this entire window and upload it with your question.
  5. If the full charge capacity and/or design capacity percentage is missing or blatantly wrong, that is an indication of battery or DC in Board failure; or worse, a Logic Board issue. See second image for an example of missing percentage values.
    • If the full charge capacity and/or design capacity percentage is missing or blatantly wrong, that is an indication of battery or DC in Board failure; or worse, a Logic Board issue.
      • See second image for an example of missing percentage values.
    • A battery usually runs at a temperature in between 50° and 95° F. Anything above that for a sustained amount of time can damage your Mac's battery.
  6. Things that can damage your computer you want to avoid...
    • Things that can damage your computer you want to avoid...
      • Knockoff non-genuine Apple MagSafe or USB-C chargers.
        • Knockoff chargers do not have the correct safety features like the genuine Apple chargers do and are unsafe for both you and your Mac Laptop.
      • Using non-genuine Apple chargers can put your device at risk for expensive repairs!
      • Cheap replacement batteries from non-reputable sellers.
        • Non-reputable sellers tend to sell cheap batteries with little to no function. These batteries tend to last only about a month or two before swelling to an unsafe size or they just stop working altogether.
      • Only buy batteries from known-trustworthy sellers! You keep your device safer and your life free of battery troubles. iFixit had an extensive range of replacement batteries for Mac Laptops if you are in need of a battery.
결론
If this guide was helpful please click the +30 button below.
다른 7명이 해당 안내서를 완성하였습니다.
Aaron Cooke
회원 가입일: 2018년 08월 28일
15,673 평판
안내서 22개 작성하였습니다
NIWOTech NIWOTech 회원
Community
0 회원들
안내서 0개 작성하였습니다
@danj Anything I can do to make this guide better? I know you are a huge coconutBattery fanatic so I wanted your opinion on this.
Aaron Cooke - 답글
You should expand a few more steps here explaining what is looked at. As an example the Battery Info button should be looked at to learn the maker of the battery likely Simplo which is one of the makers for Apple. I also look at the date of manufacture to make sure it’s not a fake battery as well to see if it’s the original. An original battery should be manufactured just a few months before the systems date.
You also want to look at what the battery is discharging at so ideally you want two snapshots one with the MagSafe connected and one without.
Then there’s the cycle count you should point them to this Apple T/N Determine battery cycle count for Mac notebooks. Once the battery is over 2/3 used its time to inspect it to make sure it has not blistered. Some batteries (third party) won’t get this far! So a cheap knockoff may fail in half of this count.
Dan -
Point them to the battery checker on the side of the system how many LED’s lit when the battery is charged (8) and if the LED’s blink battery needs replacing (same as menu icon). Sometimes the buttons need a bit of cleaning using some isopropyl alcohol as they can stick.
Then there’s dealing with calibration of the battery Calibrate & Maintain Your MacBook Battery For Best Performance.
Then there’s the issue of proper use! Many people fully discharge their systems battery before recharging which is the worse thing to do! When the battery get to be about 3/4 discharged is about the best time to recharge. You want to avoid deep discharging as each time (cycle) kills your battery. As an example my 15” MacBook Pro 2012 has its original battery and only 55 cycles used!
Dan -
I would also point them to this Apple T/N: Apple Portables: Troubleshooting MagSafe adapters so they can make sure they are using the correct MagSafe charger as well as make sure the cable and connectors are in good working shape.
The most important point is not to use a crappy MagSafe charger as there are some good knockoffs so you can’t tell just in looking at them! While is more expensive I only get from an Apple Store or directly from Apple their chargers.
Here’s some food for thought…
How hot can a battery run at?
Lastly, what does it mean when the values are wrong or just missing?
Dan -
@danj If this is a duplicate, sorry about that! I posted a comment replying to your comments but I don’t see it here.
Thanks for the feedback! Sounds like there is a lot of room for improvement. However, I am not that confident in explaining what you said needed to be added.
If you could maybe in your spare time add those things you mentioned that would be awesome! However, if you do not have time to do it or do not want to do it I completely understand. I am not doing this out of laziness, rather I just don’t want to be misleading in my instructions.
Thanks so much!
Aaron Cooke - 답글
조회 통계:
지난 24시간: 7
지난 7일: 30
지난 30일: 131
전체 시간: 683
