주요 콘텐츠로 건너뛰기
How to Test the Hardware on Your Motorola Phone
  1. How to Test the Hardware on Your Motorola Phone, Open the apps menu: 1 단계, 이미지 1개 중 1개
    • From the home screen, swipe up from the bottom of the phone to open the applications menu.
  2. How to Test the Hardware on Your Motorola Phone, Open the device help app: 2 단계, 이미지 1개 중 1개
    • Select the "Device Help" application from the menu.
  3. How to Test the Hardware on Your Motorola Phone, Select device diagnosis: 3 단계, 이미지 1개 중 1개
    • Select "Device diagnosis" from the menu.
  4. How to Test the Hardware on Your Motorola Phone, Select hardware test: 4 단계, 이미지 1개 중 1개
    • Select "Hardware test" from the menu.
  5. How to Test the Hardware on Your Motorola Phone: 5 단계, 이미지 1개 중 1개
    • You can now select which hardware test you would like to run, or you can run a full hardware test.
결승점
다른 20명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Spencer Day
회원 가입일: 09/14/22
155,120 평판
안내서 1,033개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,788개를 작성함
6가이드 댓글
is built using the open source software libraries listed below. These libraries are distributed under associated licenses, acknowledgements and required copyright notices also listed below:
Michael Lassiter - 답글
Thank you for your help and approval
What if my Motorola phone doesn't have the device help in the app menu then how do I go about running diagnostics on it OH and Just so you know I don't have any mobile data connection so I can't use the phone codes.
Sean Jacob Higgins - 답글
Having problems with my phone
Lisa Jablon - 답글
I want to see how I could take apps off Motorola moto04
Antonio “Mono” Cabrera - 답글
댓글 쓰기
조회 통계:
지난 24시간: 22
지난 7일: 181
지난 30일: 853
전체 시간: 54,152
