주요 콘텐츠로 건너뛰기
How to Tie a Tie: Four-in-Hand
필요한 것
  1. How to Tie a Tie: Four-in-Hand, Preparation: 1 단계, 이미지 1개 중 1개
    • Fold the collar of your shirt up.
  2. How to Tie a Tie: Four-in-Hand: 2 단계, 이미지 1개 중 1개
    • Wrap the tie around the back of your neck with the narrow end on the left side of your body and the wide end on the right side.
    • The wide end of the tie will be your active end.
    • Note: The narrow end of the tie should be around the height of your belly button or a little higher. It may need to adjusted for personal height.
  3. How to Tie a Tie: Four-in-Hand, Tying: 3 단계, 이미지 1개 중 1개
    • Take the active end and cross it over the narrow end, so that it points to the left.
    • Note: be sure that the tie always lays flat so there are no twists in the fabric.
  4. How to Tie a Tie: Four-in-Hand: 4 단계, 이미지 1개 중 1개
    • Wrap active end under the narrow end, so that it now points to the right.
  5. How to Tie a Tie: Four-in-Hand: 5 단계, 이미지 1개 중 1개
    • Wrap active end over the narrow end, so that it now points to the left.
    • Note: leave this wrap a little loose, as it will be used in step 7.
  6. How to Tie a Tie: Four-in-Hand: 6 단계, 이미지 1개 중 1개
    • Pull the active end up through the neck loop, so that it now points up.
  7. How to Tie a Tie: Four-in-Hand: 7 단계, 이미지 2개 중 1개 How to Tie a Tie: Four-in-Hand: 7 단계, 이미지 2개 중 2개
    • Pull the active end down through the wrap you created in step 5 (see second picture).
  8. How to Tie a Tie: Four-in-Hand, Finishing: 8 단계, 이미지 1개 중 1개
    • Tighten the knot by pulling down on the active end and up on the knot, adjusting for size and evenness.
  9. How to Tie a Tie: Four-in-Hand: 9 단계, 이미지 1개 중 1개
    • Tighten the neck loop by pulling down on the narrow end of the tie and sliding the knot up toward your neck.
  10. How to Tie a Tie: Four-in-Hand: 10 단계, 이미지 1개 중 1개
    • Tuck the narrow end of the tie through the keeper loop.
    • Note: if the narrow end is too long, a simple solution lies in tucking the narrow end between two buttons of your shirt.
    • Fold your collar down when the knot is finished.
결론
Congratulations! You've successful tied the Four-in-Hand knot!
다른 5명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Electric Warthogs
회원 가입일: 03/19/17
809 평판
안내서 3개를 작성함
The Electric Warthogs The Electric Warthogs 회원
Community
3 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 16
지난 30일: 62
전체 시간: 2,365
