주요 콘텐츠로 건너뛰기
How to Tie a Tie: Half-Windsor
필요한 것
  1. How to Tie a Tie: Half-Windsor, Preparation: 1 단계, 이미지 1개 중 1개
    • Fold the collar of your shirt up.
  2. How to Tie a Tie: Half-Windsor: 2 단계, 이미지 1개 중 1개
    • Wrap the tie around the back of your neck with the narrow end on the left side of your body and the wide end on the right side.
    • The wide end of the tie will be your active end.
    • Note: The narrow end of the tie should be around the height of your belly button or a little higher. It may need to be adjusted for personal height.
  3. How to Tie a Tie: Half-Windsor, Tying: 3 단계, 이미지 1개 중 1개
    • Take the active end and cross it over the narrow end, so it is pointing to the left.
    • Note: Be sure that the tie always lays flat so that there are no twists in the fabric.
  4. How to Tie a Tie: Half-Windsor: 4 단계, 이미지 1개 중 1개
    • Cross the active end underneath the narrow end, so it is now pointing to the right.
  5. How to Tie a Tie: Half-Windsor: 5 단계, 이미지 1개 중 1개
    • Lift the active end up over the right side of the neck loop, so it is pointing up.
  6. How to Tie a Tie: Half-Windsor: 6 단계, 이미지 1개 중 1개
    • Pull the active end down through the loop around your neck so that it is pointing down and to the left.
  7. How to Tie a Tie: Half-Windsor: 7 단계, 이미지 1개 중 1개
    • Cross it over the top of the knot to the right, so that it is now pointing to the right.
    • Note: leave this wrap a little loose, as it will be used in step 9.
  8. How to Tie a Tie: Half-Windsor: 8 단계, 이미지 1개 중 1개
    • Pull the active end up through the loop around your neck, so that it is pointing straight up.
  9. How to Tie a Tie: Half-Windsor: 9 단계, 이미지 2개 중 1개 How to Tie a Tie: Half-Windsor: 9 단계, 이미지 2개 중 2개
    • Pull the active end down through the wrap you created in step 7 (see second picture).
  10. How to Tie a Tie: Half-Windsor, Finishing: 10 단계, 이미지 1개 중 1개
    • Tighten the knot by pulling down on the active end and up on the knot, adjusting for size and evenness.
  11. How to Tie a Tie: Half-Windsor: 11 단계, 이미지 1개 중 1개
    • Tighten the neck loop by pulling down on the narrow end of the tie and sliding the knot up toward your neck.
  12. How to Tie a Tie: Half-Windsor: 12 단계, 이미지 1개 중 1개
    • Tuck the narrow end of the tie through the keeper loop.
    • Note: if the narrow end is too long, a simple solution lies in tucking the narrow end between two buttons of your shirt.
    • Fold your collar down when the knot is finished.
결론
Congratulations! You've successful tied the Half-Windsor knot!
다른 6명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Electric Warthogs
회원 가입일: 03/19/17
809 평판
안내서 3개를 작성함
The Electric Warthogs The Electric Warthogs 회원
Community
3 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 15
지난 30일: 40
전체 시간: 1,600
