주요 콘텐츠로 건너뛰기
How to Tie a Tie: Prince Albert
필요한 것
  1. How to Tie a Tie: Prince Albert, Preparation: 1 단계, 이미지 1개 중 1개
    • Fold the collar of your shirt up.
  2. How to Tie a Tie: Prince Albert: 2 단계, 이미지 1개 중 1개
    • Wrap the tie around the back of your neck with the narrow end on the left side of your body and the wide end on the right side.
    • The wide end of the tie will be your active end.
    • Note: the narrow end of the tie should be around the height of your belly button or a little higher. It may need to adjusted for personal height.
  3. How to Tie a Tie: Prince Albert, Tying: 3 단계, 이미지 1개 중 1개
    • Take the active end and cross it over the narrow end, so that it points to the left.
    • Note: be sure that the tie always lays flat so there are no twists in the fabric.
  4. How to Tie a Tie: Prince Albert: 4 단계, 이미지 1개 중 1개
    • Wrap active end under the narrow end, so that it now points to the right.
    • Note: leave this wrap, and subsequent wraps, a little loose.
  5. How to Tie a Tie: Prince Albert: 5 단계, 이미지 1개 중 1개
    • Wrap the active end over the narrow end, so that it now points to the left.
    • Note: Leave this wrap a little loose as it will be used in step 9.
  6. How to Tie a Tie: Prince Albert: 6 단계, 이미지 1개 중 1개
    • Wrap the active end under the narrow end, so that it now points to the right.
  7. How to Tie a Tie: Prince Albert: 7 단계, 이미지 1개 중 1개
    • Note: Leave this wrap a little loose, as it will be used in step 9.
  8. How to Tie a Tie: Prince Albert: 8 단계, 이미지 1개 중 1개
    • Pull the active end up through the neck loop, so that it now points up.
  9. How to Tie a Tie: Prince Albert: 9 단계, 이미지 3개 중 1개 How to Tie a Tie: Prince Albert: 9 단계, 이미지 3개 중 2개 How to Tie a Tie: Prince Albert: 9 단계, 이미지 3개 중 3개
    • Pull the active end down through the wraps you created in steps 5 (see image 2) and 7 (see image 3).
  10. How to Tie a Tie: Prince Albert, Finishing: 10 단계, 이미지 1개 중 1개
    • Tighten the knot by pulling down on the active end and up on the knot, adjusting for size and evenness.
  11. How to Tie a Tie: Prince Albert: 11 단계, 이미지 1개 중 1개
    • Tighten the neck loop by pulling down on the narrow end of the tie and sliding the knot up toward your neck.
  12. How to Tie a Tie: Prince Albert: 12 단계, 이미지 1개 중 1개
    • Tuck the narrow end of the tie through the keeper loop.
    • Note: if the narrow end is too long, a simple solution lies in tucking the narrow end between two buttons of your shirt.
    • Fold your collar down when the knot is finished.
결론
Congratulations! You've successfully tied the Prince Albert knot!
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Wes
회원 가입일: 03/29/17
535 평판
안내서 2개를 작성함
The Electric Warthogs The Electric Warthogs 회원
Community
3 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 14
지난 30일: 29
전체 시간: 678
