주요 콘텐츠로 건너뛰기
How to Tie a Tie: Trinity
필요한 것
  1. How to Tie a Tie: Trinity, Preparation: 1 단계, 이미지 1개 중 1개
    • Fold the collar of your shirt up.
  2. How to Tie a Tie: Trinity: 2 단계, 이미지 1개 중 1개
    • Wrap the tie around the back of your neck with the wide end on the left side of your body and the narrow end on the right side.
    • The narrow end of the tie will be your active end.
    • Note: The wide end of the tie should be around the height of your belly button or a little higher. It may need to adjusted for personal height.
  3. How to Tie a Tie: Trinity, Tying: 3 단계, 이미지 1개 중 1개
    • Take the active end and it cross over the wide end, so it is pointing to the left.
    • Note: be sure that the tie always lays flat so that there are no twists in the fabric.
    • Note: Be sure to keep this wrap and all subsequent wraps tight against one another.
  4. How to Tie a Tie: Trinity: 4 단계, 이미지 2개 중 1개 How to Tie a Tie: Trinity: 4 단계, 이미지 2개 중 2개
    • Wrap active end under the left side and up through the neck loop, so that it points up.
  5. How to Tie a Tie: Trinity: 5 단계, 이미지 2개 중 1개 How to Tie a Tie: Trinity: 5 단계, 이미지 2개 중 2개
    • Wrap the active end over the left side again, so that it now points down.
  6. How to Tie a Tie: Trinity: 6 단계, 이미지 1개 중 1개
    • Wrap the active end under the wide end of the tie, so that it now points towards the right.
  7. How to Tie a Tie: Trinity: 7 단계, 이미지 1개 중 1개
    • Wrap the active end over the knot, so that it now points up.
  8. How to Tie a Tie: Trinity: 8 단계, 이미지 1개 중 1개
    • Wrap the active end down through the neck loop, and pull to the left side, so that it now points left.
  9. How to Tie a Tie: Trinity: 9 단계, 이미지 1개 중 1개
    • Wrap the active end over the wide end of your tie.
    • Note: leave this wrap a little loose as it will be used in step 11.
  10. How to Tie a Tie: Trinity: 10 단계, 이미지 1개 중 1개
    • Wrap the active end under the right side and up through the neck loop, so that it points up.
  11. How to Tie a Tie: Trinity: 11 단계, 이미지 2개 중 1개 How to Tie a Tie: Trinity: 11 단계, 이미지 2개 중 2개
    • Pull the active end down through the wrap you made in step 9 (see picture 2). Then pull the active end so that it points left.
    • Note: leave this new wrap a little loose as it will be used in step 13.
  12. How to Tie a Tie: Trinity: 12 단계, 이미지 2개 중 1개 How to Tie a Tie: Trinity: 12 단계, 이미지 2개 중 2개
    • Wrap the active end under the wide tie to the right, so that the active end is pointing right.
    • Note: be sure that is tucked completely behind the wide end.
  13. How to Tie a Tie: Trinity: 13 단계, 이미지 3개 중 1개 How to Tie a Tie: Trinity: 13 단계, 이미지 3개 중 2개 How to Tie a Tie: Trinity: 13 단계, 이미지 3개 중 3개
    • Wrap active end over the knot and pull through the diagonal wrap you made in step 11 (see picture 3).
  14. How to Tie a Tie: Trinity, Finishing: 14 단계, 이미지 1개 중 1개
    • Tighten the neck knot by holding the knot and pulling on the narrow end of the tie away from you.
  15. How to Tie a Tie: Trinity: 15 단계, 이미지 1개 중 1개
    • Tighten the neck loop by pulling down on the wide end of the tie and sliding the knot up toward your neck.
  16. How to Tie a Tie: Trinity: 16 단계, 이미지 3개 중 1개 How to Tie a Tie: Trinity: 16 단계, 이미지 3개 중 2개 How to Tie a Tie: Trinity: 16 단계, 이미지 3개 중 3개
    • Tuck the rest of the narrow end into your collar and fold your collar down.
결론
Congratulations! You've successful tied the Trinity knot!
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Electric Warthogs
회원 가입일: 03/19/17
809 평판
안내서 3개를 작성함
The Electric Warthogs The Electric Warthogs 회원
Community
3 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 33
전체 시간: 871
