주요 콘텐츠로 건너뛰기
How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model
필요한 것
  1. How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model, How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: 1 단계, 이미지 1/3 How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model, How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: 1 단계, 이미지 2/3 How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model, How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: 1 단계, 이미지 3/3
    • Unlock the brake barrel adjusters fasteners with a flathead screwdriver in the clockwise direction.
    • Loosening the fasteners will help to loosen the barrel in Step 2.
  2. How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: 2 단계, 이미지 1/3 How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: 2 단계, 이미지 2/3 How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: 2 단계, 이미지 3/3
    • Twist in the clockwise direction to tighten the barrel adjusters.
  3. How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: 3 단계, 이미지 1/2 How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: 3 단계, 이미지 2/2
    • While squeezing the bike brake check the distance between the brake handle and the bike handle using a measuring device.
    • It should be about an inch if properly tightened.
    • The second image has a loose brake. The distance is less than an inch, where it should be more than an inch (reference step 8 for the right distance). This indicates that the brake is still loose.
  4. How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: 4 단계, 이미지 1/2 How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: 4 단계, 이미지 2/2
    • Prepare for the next few steps by loosening the bike brake barrel adjuster if it is fully tightened by turning it clockwise a few times.
    • Start by squeezing the brake arms together as much as possible.
  5. How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: 5 단계, 이미지 1/1
    • While maintaining the position of the brake arms from Step 4, loosen the bolt that secures the cable clamp using a 5mm Allen Wrench and turn it counter clockwise.
    • Loosen the bolt until the cable can be adjusted easily by hand.
  6. How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: 6 단계, 이미지 1/2 How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: 6 단계, 이미지 2/2
    • While keeping the bike brake arms in the same position as described in Step 5, pull the brake cable to adjust the distance between the brake pads and the wheel.
    • Stop pulling when the brake pads are one or two millimeters away from the wheel.
  7. How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: 7 단계, 이미지 1/2 How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: 7 단계, 이미지 2/2
    • With the brake arms still squeezed together, use the 5 mm Allen wrench to tighten the cable clamp by turning the wrench in a clockwise direction.
  8. How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: 8 단계, 이미지 1/2 How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: 8 단계, 이미지 2/2
    • Tighten the brake barrel adjusters again (as seen in step 2). Do this until the brake handle reaches 25.4 mm from the handle when squeezing.
    • When tightening the brakes, ensure that the brake pads never touch the side of the wheel. If this occurs, then the brake cable was pulled too tight in Step 6 and needs to be loosened.
  9. How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: 9 단계, 이미지 1/2 How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: 9 단계, 이미지 2/2
    • Finally, use the flathead screwdriver to lock the barrel adjuster fastener. Use the screwdriver to twist the fastener in a counterclockwise direction until it is tight.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Emily Arana
회원 가입일: 04/19/23
169 평판
안내서 1개 작성함
UCD-MORRIS-S23S1G1 UCD-MORRIS-S23S1G1 회원
Community
3 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 17
전체 시간: 164
