주요 콘텐츠로 건너뛰기
How to Troubleshoot Generic 1A USB Car Charger
필요한 것
  1. How to Troubleshoot Generic 1A USB Car Charger, How to Troubleshoot Generic 1A USB Car Charger: 1 단계, 이미지 1개 중 1개
    • Insert the USB Micro end into the breakout, and insert the adapter into a power source, set for 12V (or automatic if in vehicle).
    • Caution: Since your device is connected to a power source, there is a low voltage current going through that could damage components.
  2. How to Troubleshoot Generic 1A USB Car Charger: 2 단계, 이미지 3개 중 1개 How to Troubleshoot Generic 1A USB Car Charger: 2 단계, 이미지 3개 중 2개 How to Troubleshoot Generic 1A USB Car Charger: 2 단계, 이미지 3개 중 3개
    • Set the multimeter to VDC, and place the leads as shown.
    • The voltage should be about 5V.
    • If the voltage is lower, check the output of the power supply. If the power supply voltage is above 6V, then we will need to continue to Step 4.
  3. How to Troubleshoot Generic 1A USB Car Charger: 3 단계, 이미지 3개 중 1개 How to Troubleshoot Generic 1A USB Car Charger: 3 단계, 이미지 3개 중 2개 How to Troubleshoot Generic 1A USB Car Charger: 3 단계, 이미지 3개 중 3개
    • Unscrew the tip to uncover the fuse.
    • Remove the fuse from the charger.
    • Make sure to document the order that everything is unscrewed. This will be important for reassembly.
  4. How to Troubleshoot Generic 1A USB Car Charger: 4 단계, 이미지 2개 중 1개 How to Troubleshoot Generic 1A USB Car Charger: 4 단계, 이미지 2개 중 2개
    • Set the multimeter to test continuity.
    • Test to know how your meter reads a closed circuit.
    • Test the fuse with the multimeter.
    • If your fuse does not allow a current to flow, you will need to replace it.
  5. How to Troubleshoot Generic 1A USB Car Charger: 5 단계, 이미지 2개 중 1개 How to Troubleshoot Generic 1A USB Car Charger: 5 단계, 이미지 2개 중 2개
    • If the fuse is allowing a current to flow, you may move on, opening the body of the charger.
    • Be aware, there may be small springs inside body.
    • Look for small breaks in the small wires. Repair of these types of problems are outside the scope of this iFixit guide, but other guides may help.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Jay R Fude
회원 가입일: 10/10/18
320 평판
안내서 1개를 작성함
Missouri Western, Team S1-G2, Cools Stephens Fall 2018 Missouri Western, Team S1-G2, Cools Stephens Fall 2018 회원
MWSU-COOLS STEPHENS-F18S1G2
2 회원들
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 26
전체 시간: 1,995
