주요 콘텐츠로 건너뛰기
How to True Bicycle wheels
필요한 것
  1. How to True Bicycle wheels, How to True Bicycle wheels: 1 단계, 이미지 2개 중 1개 How to True Bicycle wheels, How to True Bicycle wheels: 1 단계, 이미지 2개 중 2개
    • Fit the wheel into the wheel truing stand. It doesn't matter which way the wheel is facing.
    • The wheel should be snug and securely fixed to the stand.
    • Tighten the quick-release nut and lever, making sure that there is no room for the wheel to wiggle in the truing stand.
  2. How to True Bicycle wheels: 2 단계, 이미지 2개 중 1개 How to True Bicycle wheels: 2 단계, 이미지 2개 중 2개
    • Bring the calipers up until the teeth are are about half an inch from the metal rim of the wheel.
    • Start the wheel spinning slowly.
    • Slowly tighten the calipers until they contact the wheel on one side or the other.
  3. How to True Bicycle wheels: 3 단계, 이미지 2개 중 1개 How to True Bicycle wheels: 3 단계, 이미지 2개 중 2개
    • Loosen the spoke nipples that attach to the same side of the wheel that the caliper is touching. At the same time, tighten the spokes that attach to the opposite side of the hub.
    • As a starting point, turn all the spokes half of a turn for each of the spokes near the caliper contact point.
    • In the photo, the red marked spokes are being tightened, and the blue marked spokes are being loosened. This will shift the rim closer to the viewer.
    • Spin the wheel. Tighten the calipers again until they touch the rim on only one side at a time at certain point. Repeat steps 2-3 until the caiplers touch both sides of the rim evenly at every point on the rim.
결론
The wheel should spin without wobbling from side to side or wavering up and down
다른 3명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Brett Hartt
회원 가입일: 04/12/10
131,199 평판
안내서 143개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,612개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 29
전체 시간: 5,857
