주요 콘텐츠로 건너뛰기
How to True a Bent Bicycle Rim Using Common Tools
필요한 것
  1. How to True a Bent Bicycle Rim Using Common Tools, How to True a Bent Bicycle Rim Using Common Tools: 1 단계, 이미지 1개 중 1개
    • Bring your bike somewhere with ample space so you have room to work.
  2. How to True a Bent Bicycle Rim Using Common Tools: 2 단계, 이미지 3개 중 1개 How to True a Bent Bicycle Rim Using Common Tools: 2 단계, 이미지 3개 중 2개 How to True a Bent Bicycle Rim Using Common Tools: 2 단계, 이미지 3개 중 3개
    • Flip the bike on its seat so the wheel can spin freely.
    • Use the spokes to spin the affected wheel.
    • Continue spinning the wheel until it is clear where the bend is occurring.
  3. How to True a Bent Bicycle Rim Using Common Tools: 3 단계, 이미지 2개 중 1개 How to True a Bent Bicycle Rim Using Common Tools: 3 단계, 이미지 2개 중 2개
    • Locate the bend by spinning the wheel to see where it doesn't align with the brake.
  4. How to True a Bent Bicycle Rim Using Common Tools: 4 단계, 이미지 3개 중 1개 How to True a Bent Bicycle Rim Using Common Tools: 4 단계, 이미지 3개 중 2개 How to True a Bent Bicycle Rim Using Common Tools: 4 단계, 이미지 3개 중 3개
    • Locate the two nearest spoke nipples opposite to the bend direction and tighten them a half turn using an adjustable wrench or reaming pliers.
  5. How to True a Bent Bicycle Rim Using Common Tools: 5 단계, 이미지 2개 중 1개 How to True a Bent Bicycle Rim Using Common Tools: 5 단계, 이미지 2개 중 2개
    • Pluck the spoke and listen to the pitch to check its tightness.
    • If the pitch is higher, you are tightening it, and if the pitch is lower, you are loosening it.
  6. How to True a Bent Bicycle Rim Using Common Tools: 6 단계, 이미지 2개 중 1개 How to True a Bent Bicycle Rim Using Common Tools: 6 단계, 이미지 2개 중 2개
    • Loosen the spoke nipples opposite to the ones being tightened to reduce stress in the wrong direction.
  7. How to True a Bent Bicycle Rim Using Common Tools: 7 단계, 이미지 1개 중 1개
    • Assess the dent in the bike rim and assure it's mostly straightened out relative to the break pad.
    • Repeat the tightening/loosening process accordingly if necessary.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Charles Tweedy
회원 가입일: 04/19/23
163 평판
안내서 1개를 작성함
UCD-MORRIS-S23S1G4 UCD-MORRIS-S23S1G4 회원
Community
2 회원들
안내서 1개 작성
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 43
전체 시간: 1,468
