주요 콘텐츠로 건너뛰기
How to True a Bicycle Wheel with Zip Ties
필요한 것
  1. How to True a Bicycle Wheel with Zip Ties, How to True a Bicycle Wheel with Zip Ties: 1 단계, 이미지 1개 중 1개
    • Place your bike upside down.
  2. How to True a Bicycle Wheel with Zip Ties: 2 단계, 이미지 1개 중 1개
    • Tie a zip tie next to the rim of your wheel.
  3. How to True a Bicycle Wheel with Zip Ties: 3 단계, 이미지 2개 중 1개 How to True a Bicycle Wheel with Zip Ties: 3 단계, 이미지 2개 중 2개
    • Cut the zip tie.
    • The zip tie should barely touch the rim.
  4. How to True a Bicycle Wheel with Zip Ties: 4 단계, 이미지 1개 중 1개
    • Spin the wheel and mark the spots where the rim touches the zip tie.
  5. How to True a Bicycle Wheel with Zip Ties: 5 단계, 이미지 2개 중 1개 How to True a Bicycle Wheel with Zip Ties: 5 단계, 이미지 2개 중 2개
    • Slowly loosen the spoke that is on the side of the zip tie.
    • Slowly tighten the spoke that is away from the zip tie.
    • Turn clockwise to tighten and counterclockwise to loosen.
  6. How to True a Bicycle Wheel with Zip Ties: 6 단계, 이미지 1개 중 1개
    • Repeat steps 2 to 5 with the zip tie on the other side of the wheel.
결론
Repeat the instructions on your other wheel.
작성자
1다른 기여자 명과 함께
Niyoosha Tahami
회원 가입일: 07/02/24
133 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 26
지난 30일: 93
전체 시간: 556
